Old 06-08-2015, 11:51 AM
tokola tokola is offline
Resizing/scaling panels
I am having the following problems while scaling a TabPanel:
1.Keeping its initial proportions. I've noticed that in my example (attached), setting the scale back to 1 does not reset the panel to its original size (use keys 'q' and 'w'). Might this be a combination of Tab and Grid panels or something else?
2. The included quad nodes in the GridPanel do not resize proportionally. Is this the expected behavior? Resizing them individually can be a pain.
3. How can I keep the panel in a fixed position in the window when resizing the window? Do I have to calculate the offset and change it on update (it it's not stuck on any of the corners or the center)?
Thanks!
Old 06-13-2015, 09:06 AM
Any update on this? Items 1 and 2 are still a problem. Item 3 has been replied in another thread by Jeff and appreciate it.
Thanks!
Old 06-15-2015, 05:29 PM
I'll have to check with a developer for further assistance.
Old 06-26-2015, 01:49 PM
1) There is a bug that involves the panel scaling and fontsize. This will be fixed in the next Vizard release. However, there is a workaround which is actually better than setting the font size. You can apply an additional scale to the "gridPanel", which will be relative to it's inherited scale from the parent tabPanel. So instead of changing the font size, do something like the following:
gridPanel.setPanelScale(1.75)
Below is an example:
import vizdlg
tabPanel = vizdlg.TabPanel()
gridPanel = vizdlg.GridPanel()
tabPanel.addPanel('TEST',gridPanel,viz.ALIGN_LEFT_TOP)
rowText = viz.addText('TEXT')
gridPanel.addRow([rowText])
viz.link(viz.LeftTop,tabPanel,offset=(10,-10,0))
vizact.onkeydown('1',tabPanel.setPanelScale,1)
vizact.onkeydown('2',tabPanel.setPanelScale,2)
2) Yes, only GUI objects will scale with the panel scale. If you just want to have a textured quad you could add a textured checkbox and that will scale with the panel:
quad = viz.addCheckbox()
quad.setScale([3,3,1])
quad.disable()
quad.texture(viz.addTexture('lake3.jpg'))
gridPanel.addRow([quad])
Custom-permanent tooltip tokola Vizard 2 06-09-2015 02:20 PM
