Old 05-18-2015, 07:10 AM
ccjohnston ccjohnston is offline
Top-down path taken image from vizard coordinates?
Is there a way to convert output vizard coordinates into an image? That is, is there some way to take the coordinates and produce an image of the path from a top-down view? Thank you.
Old 05-18-2015, 10:21 AM
Take a look at the on-the-fly tutorial. That shows how to draw a path of the viewpoint movement in a top-down view.
Old 05-19-2015, 07:11 AM
Thank you. Hmm, is there a way to have an image of the path from already-done runs through the maze? I have files with coordinates over time that I want to see in the form of an image of the path the subject took. Is that possible?
Old 05-19-2015, 07:31 AM
Sorry I'm not being clear--I'm having a hard time articulating my question. I don't want a window showing the path taken from a top-down view as the subject is running through the maze. Instead, I want an image produced after the maze is already run through, where the image shows the path that was taken when the subject was running through the maze. I hope that makes sense.
We have coordinate files already that looks like this:
Coordinates:
[[ 0.00000000e+00 3.99644127e+01 0.00000000e+00 0.00000000e+00]
[ 0.00000000e+00 3.99350586e+01 0.00000000e+00 0.00000000e+00]
[ 0.00000000e+00 3.96772919e+01 0.00000000e+00 1.59997940e-02]
[ 0.00000000e+00 3.97072945e+01 0.00000000e+00 3.09998989e-02]
(...etc.)
So, I was wondering if we could take this coordinate data and produce an image of the path that that subject took.
Old 05-19-2015, 10:03 AM
If you want an image of pre-recorded data you could read in the data from file, draw the path, and then take a screenshot of the window.
Old 05-19-2015, 10:07 AM
If you want to automate the image capture, then use Vizard's built in screen capture commands.
Vizard automatically scaling image to an aspect ratio of 1:1 Frank Verberne Vizard 3 01-13-2014 08:48 AM
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 07:17 AM
