Old 04-22-2015, 07:17 AM
krimble krimble is offline
CAL3d: Could not find plugin to read objects from file
Hi all,
I'm wondering if someone had a problem like this before.
. I exported a Cal3d Avatar with 3dsMax 2015.
. No export problems.
. When importing in Vizard: avatar = viz.add() the avatar appears in resources and when double clicking it displays the avatar in the graphics window.
. in graphics window there's something going with textures but they're all messed up.
. when running the script, I don't see an avatar but get this error message
Warning: Could not find plugin to read objects from file "# cal3d material data
Name body[0]
Type Standard
Map Diffuse 0 1 casual10_f_30.tga UVMAP_EXPLICIT 0
SelfIlluminationColorMode 0 0
SpecularLevel 1
Any help is appreciated!!
Thanks!
Best, Jeroen
Max Planck for Psycholinguistics
Old 04-22-2015, 03:05 PM
Make sure you follow all the steps in the Cal3D workflow documentation. Let us know if you still have issues after that.
Old 04-24-2015, 01:42 AM
Hi Jeff,
thanks for your fast reply!
I used the cal3d guide your send me. But this only made the avatar look better in the gui graphics window. The problem with not loading the avatar when running the script is still there.
I've attached a screenshot.
I'm using 3dsmax 2015, Vizard 4 and the Cal3d 2015 exporter downloaded from worldviz.com
Thank you for your help!
Best, Jeroen
Old 04-28-2015, 02:12 AM
Dear Jeff,
as far as I know I followed the cal3d export procedure correctly.
1. I tried to load the avatar into vizard 5 (was using 4 before).
When running the script, I'm not getting any errors but can't see the avatar at all.
2. When double clicking the avatar.cfg, the inspector tries to open but gives me an error, "Vizard inspector has stopped working".
Can someone please give me any pointers on what is going wrong here?
Thank you!
Best, Jeroen
Old 04-29-2015, 07:42 AM
Hi again,
I tried to export an avatart from the worldviz character pack.
Opened the max file, and exported with the Cal3d 2015 exporter.
I'm experiencing the same problems in Vizard 4.0 and get the same error message (read one post up) in Vizard 5.0.
I'm not sure what's going on. Is the Cal3d exporter not working properly?
Thanks!
Old 04-29-2015, 08:39 AM
Please upload your exported files for us to take a look at.
Old 04-30-2015, 02:25 AM
Thanks! I uploaded the files (JDerksAvatarFiles.zip)
Old 05-01-2015, 12:45 PM
We got the files and one of our artists will take a look.
Old 05-15-2015, 12:40 PM
Hi krimble,
I tried loading your avatar from the cal3dAvatar folder into Inspector, and found the following issues:
* Through disabling various lines in the CFG, I was able to determine there was something wrong with the mesh itself. Possibly exported with bones selected or something like that.
* "Scale" setting used in CFG, which is no longer necessary with avatars that are exported completely with the current exporter.
* The texture that was being loaded onto the mesh did not make sense for that avatar. (underwear texture loaded onto avatar wearing clothes)
Exporting "avatar.max" into Cal3D from Max 2015 on my end produced a usable cal3d avatar, so it looks like you may making a mistake when exporting.
You can find a version of that avatar here:
http://www.uploadthingy.com/widget?c...el=1412610.zip
Old 05-20-2015, 02:12 AM
Veleno and Jeff,
thank you very much for your help! I'll compare both avatars to sort out what was going wrong here.
Best, Jeroen
"Could not find plugin to read objects" error? jfenster Vizard 3 02-27-2013 11:35 AM
Error: Could not find plugin to read objects from file jde Vizard 3 02-15-2012 01:49 PM
Incampatible CAL3D files luakt Vizard 4 09-14-2008 11:28 PM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 02:16 PM
