Old 01-26-2015, 08:15 PM
fivel_lab fivel_lab is offline
vizinput disables keyboard?
OK another weird one... We are finding that after a script executes vizinput.choose (or vizinput.input), the keyboard is disabled so that any keydown events (including ESC) don't get detected. For example, the following code works just fine until the commented line is un-commented:
import vizinput
import vizshape
def setVisibility(blah):
	theball.visible(blah)
#vizinput.choose('blah', ['fsdg','sd'])
theball = vizshape.addCircle()
theball.setPosition(0,0,4)
vizact.onkeydown('n', setVisibility, viz.TOGGLE)
no clue how to solve this one..
Old 01-29-2015, 03:44 AM
The vizinput dialogs create a blocking action which will halt rendering and events. If you want the user to make selections while the script runs normally you can use one of Vizard's other GUI libraries. Does this work for you?
import vizinfo
import vizshape
info = vizinfo.InfoPanel('Press n to toggle visibility of the ball')
dropdown = info.addLabelItem('blah',viz.addDropList())
dropdown.addItems(['fsdg','sd'])
theball = vizshape.addCircle(pos=[0,1.5,5])
vizact.onkeydown('n', theball.visible, viz.TOGGLE)
vizinput module missing whaleeee Vizard 1 02-06-2013 12:30 AM
User keyboard input without halting the program Zhi Vizard 2 06-23-2011 01:53 PM
Keyboard shortcuts for debugging kopper Vizard 6 03-25-2011 06:23 PM
Question about input from virtual keyboard. yyang Vizard 4 12-23-2008 01:25 PM
On Screen Keyboard betancourtb82 Vizard 14 10-03-2006 01:38 PM
