Old 11-10-2014, 04:28 AM
pradeep pradeep is offline
Working in Haptic device (PHANTOM)
Hello
I am working with "sensable PHANTON Omni" & "Worldviz 5".
I have created boundary for the car which will not allow the car to go beyond that walls (cube1 & cube2).
I want to implement fillowing effects in the code
1) When car touch/strike with boundary, I want to generate opposite force in haptic device that give the feel of the wall.
2) I want to add spring effect from the point [0,0,0] in all direction
Kindly give your suggestions to implement bounding ares for car.
The code is:
import vizshape
viz.setMultiSample(4)
viz.fov(60)
viz.phys.enable()
viz.collision(viz.ON)
car = viz.add( 'mini.osg' )
car.collideBox()
ViewCarLink = viz.link(car,viz.MainView)
ViewCarLink.preEuler( [0,30,0] )
ViewCarLink.preTrans( [0,0,-10] )
ViewCarLink.preEuler( [0,-20,0] )
ground = viz.addChild('ground.osgb')
ground.collidePlane()
sensable = viz.add('sensable.dle')
device = sensable.addHapticDevice()
device.workspace.setScale([20,20,20])
device.addNode(ground)
#right boundary for car
cube1 = vizshape.addCube(size=1)
cube1.setPosition([2,0.5,8])
cube1.setScale(20,1,0.2)
cube1.setEuler(90,0,0)
RightB=cube1.collideBox([20,1,0.2])
RightB.density=10000
#left boundary for car
cube2 = vizshape.addCube(size=1)
cube2.setPosition([-2,0.5,8])
cube2.setScale(20,1,0.2)
cube2.setEuler(90,0,0)
LeftB=cube2.collideBox([20,1,0.2])
LeftB.density=10000
def UpdateMovement():
    elapsed = viz.elapsed()
    x,y,z = device.getPosition()
    forwardMovementAmount = viz.elapsed() * (z+0.5)
    car.setPosition( [ 0, 0, forwardMovementAmount], viz.REL_LOCAL )
    rotationAmount = viz.elapsed() *(x)*10
    car.setEuler( [ rotationAmount, 0 , 0 ],viz.REL_LOCAL)
    #add spring effect
    device.addSpringEffect( gain=10,magnitude=10,position=[0,0,0])
vizact.ontimer(0, UpdateMovement)
Old 11-10-2014, 04:13 PM
1) Make sure the walls are added to the haptic simulation using the device.addNode(node) command. The front of the car (not center) should be aligned with the haptic device if you want resistance when the front touches the wall.
2) The following code should add a spring effect:
spring = device.addSpringEffect(gain=0.2,magnitude=0.5,position=[0,0,0])
How to get real time position of a object which is connected to a haptic device Melody Vizard 4 09-15-2014 03:35 PM
haptic device problem guof6570969 Vizard 2 06-09-2010 03:37 AM
Haptic Device Shadows vTony Vizard 1 05-04-2009 06:58 PM
Phantom Omni Device Scripts vSuejung Vizard 1 09-17-2008 05:42 PM
Phantom Device Getting Stuck vjosh Vizard 1 05-09-2005 12:16 PM
