Old 11-04-2014, 07:05 AM
JB_HP_Viz JB_HP_Viz is offline
In there a way in Vizconnect to allow user to select between different input devices
Checking to see if there is a way in Vizconnect to allow the user to select controlling the MainView with either a Joystick, a tracker, a Kinect, keyboard/mouse or any other input device?
I can see how to do it using viz.link in the example code below where I have allow the user to choose between a Joystick or Keyboard Tracker using keys on the keyboard to change which controls the MainView. Just checking to see if there is a way to do this using Vizconnect?
import sys
import vizconfig
import vizcam
viz.setMultiSample(4)
viz.fov(60)
import vizinfo
vizinfo.InfoPanel()
# Setup keyboard/mouse tracker
keyboard_tracker = vizcam.addWalkNavigate(moveScale=2.0)
keyboard_tracker.setPosition([0,1.8,0])
# Get list of joystick device information
dinput = viz.add('DirectInput.dle')
devices = dinput.getJoystickDevices()
# Exit if no joystick detected
if not devices:
	sys.exit('No joystick devices connected')
# If there is more than one device, then display selection dialog
if len(devices) > 1:
	selected = viz.choose('Select joystick device', [ d.productName for d in devices ])
	selected = 0
# Connect to selected device
joy = dinput.addJoystick(devices[selected])
if not joy:
	sys.exit('Failed to connect to joystick')
# Set dead zone threshold so small movements of joystick are ignored
joy.setDeadZone(0.2)
# Display joystick information in config window
vizconfig.register(joy)
vizconfig.getConfigWindow().setWindowVisible(True)
# Create node for applying joystick movement and link to main view
joystick_node = viz.addGroup(pos=(0,1.8,0))
viz.link(joystick_node, viz.MainView)
# Use joystick axes to move joystick node
# Horizontal (X) axis controls yaw
# Vertical (Y) axis controls position
MOVE_SPEED = 5.0
TURN_SPEED = 90.0
def UpdateJoystickMovement():
	e = viz.elapsed()
	x,y,z = joy.getPosition()
	joystick_node.setEuler([x * TURN_SPEED * e, 0, 0], viz.REL_LOCAL)
	joystick_node.setPosition([0, 0, y * MOVE_SPEED * viz.getFrameElapsed()], viz.REL_LOCAL)
vizact.ontimer(0, UpdateJoystickMovement)
# Reset joystick when joystick button 0 is pressed
def ResetPosition():
	joystick_node.setPosition([0,1.8,0])
	joystick_node.setEuler([0,0,0])
vizact.onsensordown(joy, 0, ResetPosition)
# Add environment
viz.addChild('maze.osgb')
def linkJoystick():
vizact.onkeydown('j', linkJoystick)
def linkKeyboard():
	viz.link(keyboard_tracker,viz.MainView)
	viz.mouse.setVisible(False)
vizact.onkeydown('k', linkKeyboard)
thank you
John
Old 11-04-2014, 12:12 PM
In the script that imports the vizconnect config you'll want to get a handle to the display (which includes the viewpoint) and whatever trackers/transports you'll want to set as the parent of the display. Then you can change the display's parent through the code. Here's a simple example:
import vizconnect
vizconnect.go('vizconnect_config.py')
viz.addChild('piazza.osgb')
keyTracker = vizconnect.getTracker('keyboard')
mouseKeyTracker = vizconnect.getTracker('mouse_and_keyboard_walking')
display = vizconnect.getDisplay()
vizact.onkeydown('1',display.setParent,keyTracker)
vizact.onkeydown('2',display.setParent,mouseKeyTracker)
Old 11-05-2014, 12:40 PM
Thank you. Just tested, works great.
John
multi user environment tutorial maya Vizard 0 11-23-2013 08:35 AM
User keyboard input without halting the program Zhi Vizard 2 06-23-2011 12:53 PM
Controlling User Input ohad Vizard 1 03-15-2010 05:16 PM
User Input Hodge1620 Vizard 2 11-17-2005 06:58 AM
user input problem Jerry Vizard 1 11-16-2005 03:15 PM
