Old 10-30-2014, 04:14 PM
jsnider jsnider is offline
old plugin interface
Is the old plugin interface (sensor.h, VRUTSensor, etc...) available in vizard 5? I definitely like the new interface better for new things, but I'd like to reuse old plugins too.
Joe
Old 11-05-2014, 09:44 AM
Vizard 5 will still load plugins using the old interface. The new SDK does not include the old-style sensor header files. However, if you have them from the previous SDK, then it should compile and work fine with Vizard 5.
There is one caveat: if your plug-in uses any OSG libraries, then you will need to use the newer OSG header/lib files from the Vizard 5 SDK.
Creating a Vizard Sensor Plugin farshizzo Plug-in development 25 08-01-2019 12:24 AM
Live Characters plugin Frank Verberne Vizard 7 03-01-2012 02:23 AM
viz.Screen Images overlap and Interface Button jaylocco Vizard 1 08-28-2009 03:18 PM
Howto debug a custom plugin? reedev Plug-in development 3 04-23-2009 02:16 PM
