Old 10-27-2014, 12:14 PM
Melody Melody is offline
Can I apply nonlinear force to haptic device in vizard?
Can I apply nonlinear force to haptic device?
For example, F=x^2 (x is changing all the time)
Please let me know. Thank you so much.
Old 10-27-2014, 06:24 PM
You could update the magnitude of the effect over time using the <effect>.setMagnitude command.
Old 10-28-2014, 07:52 AM
Thanks!
I think I should update the constant effect. Correct?
Old 10-28-2014, 04:42 PM
Yes, you could add a constant effect with changes to the magnitude.
Old 10-29-2014, 05:51 PM
Thank you so much, Jeff!
How to get real time position of a object which is connected to a haptic device Melody Vizard 4 09-15-2014 03:35 PM
where can I download example scripts about force effects based on haptic device Melody Vizard 9 08-29-2014 04:15 PM
Coordinate Transforms: Vizard to Haptic VDong Vizard 1 05-14-2009 08:46 AM
problem talking to usb device in Vizard Vbents Plug-in development 2 06-15-2006 04:08 PM
