Old 10-17-2014, 10:59 AM
Qiliang He Qiliang He is offline
Turn on Collision, but still can go through
This is a weird thing. I turn on the collision using viz.collision(viz.ON), and all of the objects inside the boundary are impenetrable. But the problem occurs on the boundary. When I go really hard to the wall, sometimes I can go through!?
Does anybody have this experience? I use google sketchup to make the objects.
Old 10-17-2014, 01:50 PM
How are controlling the viewpoint movements? Does the viewpoint go through when using the standard mouse navigation with default speed?
Old 10-18-2014, 11:43 AM
Thank you for your prompt reply!
Yes. I use vizcam.KeyboardCamera with default speed and viz.WalkNavigate, and both of them would go out of the boundary if I keep hitting the wall.
I also implement the joystick version, same result. But I have to emphasize that it only happens when you try to hit the wall for more than 1 second.
Old 10-20-2014, 03:36 PM
Do you still have this issue if you export the model with the Export Two-Sided Faces option enabled?
Old 11-03-2014, 11:26 AM
Oh, you are a genius. Thanks!
Turn off collision of mainview partially Marco Vizard 2 05-30-2014 05:02 AM
Collision Exception jassel41 Vizard 2 11-09-2010 06:08 PM
Collision and avatar animation shahramy Vizard 2 10-27-2010 12:47 AM
Collision notifications CarlosRamos Vizard 3 05-25-2010 03:33 PM
Collision with child nodes rubberpimple Vizard 4 09-17-2008 05:27 PM
