Old 09-24-2014, 02:48 AM
disbeat disbeat is offline
Laptop for running vizard with high performance
I am looking for a laptop to run vizard experiences smoothly. I need high performance and combine with Oculus Rift and I might use it to collect physiological data at the same time.
Which graphic card should I buy, or even if there is a recommended laptop you would suggest. I have some budget (~2.5K€).
Thanks for your input,
Marco
Old 09-29-2014, 04:33 PM
For high performance we recommend higher end GeForce cards when active stereo (e.g. shutter glasses) is not required.
Old 10-09-2014, 01:02 PM
brunomartelli brunomartelli is offline
My MacBook Pro is a face melter- gives high frame rates at hi res in bootcamp
Old 10-22-2014, 12:50 AM
Aurora Zabala Aurora Zabala is offline
Hi, I think a hybrid graphics is recommended for a high performance laptop. I just do not know, if it will work on a running vizard with typically high performance
Old 11-14-2014, 04:24 AM
johnallen johnallen is offline
disbeat (marco) - I'm in the same boat so I was wondering whether you've found something suitable yet or at least advanced your idea of what you require?
I'm thinking W8.1 x64 (I want to use the kinect v2 + oculus)
Ideally I'd like something with docking station support too.
Does Vizard work on 3D Laptop johnnyiowa Vizard 1 01-05-2011 01:30 AM
