Old 08-19-2014, 05:50 AM
Alex Miranda Alex Miranda is offline
Move an object on four screen
Hey everyone, I wanna show four screens on four displays.
I created four screens like that:
Camera_01_Window = viz.addWindow()
Camera_01_Window_View = viz.addView()
Camera_01_Window.setView(Camera_01_Window_View)
Camera_01_Window.setPosition([EixoXPositionCamera_01, EixoYPositionCamera_01])
Camera_01_Window.setSize(EixoXCamera_01,EixoYCamer a_01)
I can't move an object separately. My object should be positioned in a different position on each display
Exemple: In the first screen only a part of the object will be shown on the right corner, so the another part will be shown on the left corner of the second screen. I've tried do the implementation using "setPositon" and "Move", but all object are moved together. I would be grateful if you could help me.
I hope someone can help,
Thanks.
Old 08-19-2014, 06:56 PM
If you want to show one object from different viewpoint locations then you need to have a separate viewpoint for each window and change the viewpoint position/orientation.
If the viewpoint location is the same for all windows but you want to have one object showing up in different positions in that view you can add the model 4 times. Each model can then be rendered to a single window using renderOnlyToWindows.
Old 08-20-2014, 06:27 AM
But if I do this, my object will have more polygons to be rendered
Old 08-20-2014, 10:55 AM
Sorry, I don't understand exactly what you're trying to do. You can clone the model to conserve memory:
viz.MainWindow.setSize([0.5,1])
subWindow = viz.addWindow(pos=[0.5,1.0])
subWindow.setSize([0.5,1])
ball = viz.addChild('beachball.osgb',pos=[0,2.5,3])
ball2 = ball.clone(pos=[0,1,3])
ball.renderOnlyToWindows([viz.MainWindow])
ball2.renderOnlyToWindows([subWindow])
Old 08-20-2014, 01:23 PM
I've looked at the code in the link you sent me and I'm using now, but I'm having trouble with memory, maybe I can use this another code you've posted right now. I have a project on college using the Vizard and I need show an object on four display as just one.
Get object name from an X/Y screen coordinate williamchappell Vizard 2 08-08-2013 01:08 PM
How to move a text object and its children text objects as a whole knightgba Vizard 2 08-24-2010 10:21 AM
How can I select and move an object? nlfrnassimi Vizard 1 02-11-2009 01:08 AM
Getting object position in screen coordinates v-Salik Vizard 1 10-19-2007 03:41 PM
Move texture from one object to another Johannes Vizard 2 02-09-2005 03:55 PM
