Old 08-18-2014, 12:56 PM
armo armo is offline
DeprecationWarning when running a yield statement
Hello
I am working on this script where I run a task, wait for the user to give a mouse response and store the reaction time. Below is the task:
def example_trial():
    response = viz.Data()
    startTime = viz.tick()
    yield viztask.waitMouseDown( None, response )
    print 'response at: ', viz.tick()
    reactionTime = response.time - startTime
    print reactionTime
but when it comes to the yield line it gives me this warning, and I can't figure out what it means and how to fix it
DeprecationWarning: "data" option will be removed in future versions, use "[data] = yield [condition]" instead
P.S. I have run the same code with a previous Vizard version and then I didn't get the warning
Old 08-18-2014, 02:58 PM
The viztask.waitMouseDown command has been updated and no longer expects the viz.Data object to be passed as an argument. Use the following instead:
	response = yield viztask.waitMouseDown( None )
	print reactionTime
Old 08-19-2014, 11:23 AM
To be clear, this is just a warning. Your existing code should still function properly. Deprecated functions are not removed until the next major version, so you have until Vizard 6 to update your code.
If you would like to simply disable the warnings, then add the following code to the beginning of your script. However, I would strongly recommend that you just update your code.
import warnings
warnings.filterwarnings("ignore", category=DeprecationWarning)
Old 08-20-2014, 05:41 AM
Dear all
Thanks for the reply. There is no problem for me about updating my code but I would ask you if I can still use the "response.time" variable as it was written in the snippet above in order to calculate user's reaction time and the "response.button" in the snippet below to obtain the mouse button:
if response.button == viz.MOUSEBUTTON_LEFT:
    outResponse = "left response"
elif response.button == viz.MOUSEBUTTON_RIGHT:
    outResponse = "right response"
regards, armo
Old 08-20-2014, 10:35 AM
Yes, the data object returned by viztask.waitMouseDown still contains that information.
condition, data, deprecation, warning, yield
Unexpected Avatar lookAt() behavior when using yield statements chris2307 Vizard 2 12-17-2013 02:58 AM
connecting to SMI iViewX running a RED tracker pkhoosh Vizard 11 10-20-2011 04:17 PM
running experimental trials fivel_lab Vizard 3 03-18-2011 02:58 PM
exiting a yield statement starbug Vizard 2 01-12-2010 03:16 PM
Problems running R3 and R2.5 on the same computer cade_mccall Vizard 5 09-05-2006 11:26 AM
