Old 07-24-2014, 11:05 AM
Daniel1 Daniel1 is offline
Exclamation Intersense-900 wand and headtracker
I am currently working on a project using Intersense 900. I am trying to use my wand and head tracker to navigate through virtual environment. I can use my mouse to navigate the virtual environment, but I can't use my wand and head tracker. I tried using the following code, but still can't navigate the displayed window with the wand and head tracker.
viz.go(viz.QUAD_BUFFER)
viz.clearcolor(viz.BLUE)
PORT_INTERSENSE = 3
isense = viz.add ('intersense.dle')
tracker1 = viz.add('intersense.dle')
tracker2 = viz.add('intersense.dle')
station1 = isense.addTracker(port =3,station=1)
station2 = isense.addTracker(port =3,station=2)
Below is the result..
http://www.intersense.com
Tel: 781-541-6330
Thu Jul 24 12:51:03 2014
Looking for InterSense tracking device number 1.
Please wait
IS-900 Series device detected on port 3, 115200 Baud
Firmware Version: 4.2008
Please is there anything that I need to do to make it work?
Old 07-24-2014, 12:14 PM
It seems like you've established the connection but need to apply the sensor data to the viewpoint. Take a look at the vizconnect tutorials for instructions on applying tracker data to the view and saving that to a configuration file.
Old 07-24-2014, 03:19 PM
Exclamation
Hello Jeff,
Thanks for your reply. I did all you ask me to do according to the link provided, and I also tried to add wand tracker to it with the code bellow, but it's gave me an error. Please I need your help again. How can I solve this error problem? ERROR: Failed to create extension sensor with intersense.dle
code:
viz.setMultiSample(4)
vizconnect.go('vizconnect_config.py')
PORT_INTERSENSE = 3
tracker = isense.addTracker(port =3)
#keyTracker = vizconnect.getTracker('keyboard').getNode3d()
tracker0Tracker = vizconnect.getTracker('tracker0').getNode3d()
import vizshape
axes = vizshape.addAxes()
#viz.link(keyTracker,axes)
viz.link(tracker0Tracker,axes)
The errors are:
** ERROR: Failed to connect to Intersense tracker on port 3
** ERROR: Failed to create extension sensor with intersense.dle
File "<string>", line 11, in <module>
File "C:\Documents and Settings\STUDENT\Desktop\Displays and tracker\dispalys_trackers_tutorial.py", line 14, in <module>
File "C:\Program Files\WorldViz\Vizard5\python\vizconnect\__init__. py", line 2152, in getTracker
return getNode(classification=CLASS_TRACKER, name=name)
Old 07-28-2014, 09:59 PM
Make sure no other Intersense software is running that connects to the IS-900 when you run Vizard or Vizconnect. In your first post, the script output showed a connection to the tracker. Did anything change in the setup?
