Old 07-16-2014, 01:07 AM
Rupsha Rupsha is offline
adding audio problem
hello world viz forum...i am facing a problem in vizard 5 beta....I recorded my voice in audacity in .wav format and am trying to add it in my environment to make the avatar speak that recorded audio. Though the audio is getting added in the resources and is also playing but when i add it to my environment, it's not working...the avatar is not speaking. The inbuilt jfk.wav file in vizard help is playing. Please suggest me the solution.
Old 07-16-2014, 06:49 PM
Can you post the code you're using and are you getting any error?
Old 07-17-2014, 05:00 AM
Did you record your voice in stereo mode? If so, you should convert your .wav file to mono, because the vizact.speak function only works with mono tracks. See https://www.youtube.com/watch?v=ZJ-Nq-os2YI for more information on doing so.
Adding Audio to CAF Animation WaterBottle Vizard 3 08-30-2011 07:54 PM
The problem of adding two .ive models hengshan.li Vizard 1 08-08-2011 01:04 AM
Vizard problem mizutani_jun Vizard 4 01-09-2011 04:39 PM
Problem on adding OSG file felixchc Vizard 4 10-06-2006 12:26 PM
problem with female animations vmonkey Vizard 1 10-07-2005 11:36 AM
