Old 05-29-2014, 07:10 AM
johnallen johnallen is offline
quick way to center a room at 0,0 ?
I have a ppt 4 camera tracking system in my lab space (+ am running vizard v4)
I've built a simple room the exact size of my lab in 3dsmax and exported it to osgb
that all works fine
except that my room is 90degrees mis orientated and also offset in both x & z.
I can use room.seteuler(90,0,0) ok but using room.setposition(x,y,z) is really fiddly to get right.
Is there an easier way to just say position my room so that the center of it is at 0,0,0 ?
or am i better to go back to 3dsmax and edit the position at source (not sure how easy that would be as i'm new to it)
many thanks for any suggestions,
John
Old 05-29-2014, 11:41 PM
The best solution is to fix the origin and orientation in Max before exporting to Vizard. You should be able to move the room so its center is just above the origin in Max.
Old 06-11-2014, 07:38 AM
Thanks for the advice.
I did as you suggested and fixed it at source in Max { right click | move | set the x,y,z coordinates to zero }
room scene position
Eye position relative to center of head? performlabrit Vizard 1 01-07-2014 09:30 AM
room tilting when moving head up and down with HMD Nvis SX111 karinp Vizard 7 01-24-2012 04:01 AM
Setting the origin of a object to an object's center Aweless Vizard 1 06-28-2011 01:57 AM
i want to ccreate a room for a virtual reality applications nasruddin Vizard 1 03-20-2009 10:55 AM
Positioning objects: center johannes2 Vizard 2 02-12-2008 03:56 AM
