Old 04-11-2014, 02:59 PM
Moh200jo Moh200jo is offline
Connect Wii fit remotes
Hi Folks
May I ask if I will be able to use 5 Wii fit remotes in order to get their acceleration data by using Wiimote plugin?
Old 04-14-2014, 05:00 AM
I'm not exactly sure what the Wii fit remote is. If that is a standard Wiimote then you can connect to multiple devices in Vizard. First you must establish connections with all Wiimotes in the Bluetooth driver software.
Old 04-17-2014, 03:29 PM
Hi Jeff,
Thank you very much. Yes I meant a a standard Wiimote.
I am wondering if there is any recommended Bluetooth by Vizard?
Thanks.
Old 04-17-2014, 03:46 PM
May I also ask if I can connect Wii balance board?
Old 04-18-2014, 12:24 AM
The plug-in supports just the wiimote. There might be 3rd party python libraries for connecting to the wii balance board available.
Old 04-27-2014, 11:04 AM
Hi Jeff,
Thank you very much for this info. I find this wiiboard-simple so I am not sure if this will work with Vizard?
Would you mind please to advice if there is any recommended bluetooth device?
Mohammad
Old 04-28-2014, 09:52 AM
We have not tested this library so I can't say for sure. That page says it requires Python 2.5 and Vizard 4 uses Python 2.7.
In terms of wiimote bluetooth drivers it's probably best to search online for current suggestions. There is some mention of drivers in old wiimote threads on this forum but that could be out of date.
New error in trying to connect Vizard and Liberty Latus Yang Vizard 0 02-22-2013 12:43 PM
Failed to connect to intersense Karma Precision Position Tracker (PPT) 1 07-01-2011 02:48 PM
Cyberglove left hand not able to connect llqqff Vizard 2 07-21-2010 12:47 PM
To connect processes Woosuk Jang Vizard 0 06-30-2009 03:19 PM
PPT talk button error: Failed to connect to COM4 jpq Precision Position Tracker (PPT) 3 12-08-2005 03:36 PM
