Old 04-02-2014, 01:08 PM
OSG Switch
Is it possible to toggle the switch OSG node in the inspector from 3ds max?
I can see the node in 3ds max, however I don't see any direct way to change the state of any of the objects in the switch.
~George
Old 04-15-2014, 01:13 AM
If you are referring to toggling switch nodes within Inspector, then that ability will be in the next release.
Old 04-15-2014, 12:26 PM
Yes I was, thank you.
Old 07-23-2015, 12:24 PM
lee.cofer lee.cofer is offline
How do you toggle the OSG node switch from your vizard code?
Old 07-25-2015, 01:42 PM
Is toggling a switch node possible using vizard? Any suggestions would be appreciated.
Button to switch between infoboxes in gui rage1 Vizard 1 08-29-2011 10:37 AM
Creating a loop to switch between menu pages RodRSpv Vizard 1 03-02-2009 02:19 PM
How to switch between menu screens RodRSpv Vizard 1 03-02-2009 02:18 PM
I want to be able to switch the sensor data being sent to the HMD from the PPT v-Salik Vizard 1 04-10-2008 02:28 PM
switch statement vrlab Vizard 1 08-04-2004 10:23 AM
