Old 04-10-2014, 12:36 PM
Alex Miranda Alex Miranda is offline
Set Size ViewPoint by Keyboard
Firstly, i would like to thanks everyone that helped me, and I have more one question. How can I set the size of window using keyboard?
For example: I've defined "upLeftWindow.setSize(.436, .93)", but for using the correct size, i need to do many tests to find it. If i wanted use to any button to set it in real time, would be possible?
Old 04-11-2014, 07:12 AM
Erikvdb Erikvdb is offline
Sure, <window>.setSize() works during runtime as well, so for finding the right window size by tweaking it step-by-step you can have a little code like this:
x = 0.5 #initial size window X
y = 0.5 #initial size window Y
upLeftWindow = viz.addWindow()
upLeftWindow.setSize([x,y])
upLeftWindow.setPosition(0,1)
upLeftWindow.clearcolor(viz.WHITE)
def onKeyDown(key):
	global x, y
	if key == '-':
		x -= 0.05 #step size
	elif key == '=':
		x += 0.05 #step size
	print x, y
Pressing - or = will increase or decrease the X size of the window, you can map other keys for the Y size in a similar fashion.
Old 04-15-2014, 08:21 AM
Run!
Thank for help me! The code run!
How to track the actual viewpoint Jerry Vizard 3 05-25-2016 10:44 AM
Unexpected Change of Window Size javadi Vizard 7 07-23-2013 03:56 PM
Intermittent orthographic stereo projection problems AySz88 Vizard 10 02-17-2012 01:50 PM
Avatar w/ hat cannot look at viewpoint TrashcanPatrol Vizard 5 08-19-2008 09:26 AM
VRML Viewpoint error bstankie Vizard 1 03-11-2003 03:10 PM
