Old 04-11-2014, 08:35 AM
Timestamps on Arrington data? VPX.dll?
I'm attempting to use the Arrington interface, but want accurate timing data.
Although the Vizard plugin does not provide a function to get accurate timing information, the Arrington SDK does, with its function:
VPX_GetDataTime2(0,pointerToACTypeDouble);
I was hoping to use the arrington.sendCommand() function, but seems to only be able to send command line interface functions.
I've seen mention of Vizards vpx.pyd module, but see no documentation.
Any advice?
Old 04-11-2014, 10:42 AM
Solved! Here's a way to access the SDK functions directly, using ctypes module's DLL support. Special thanks to Flip Phillips at Skidmore College for the solution.
from ctypes import * # eyetrackka
import os
vpxDll = 'C:\ViewPoint 2.9.2.5\VPX_InterApp.dll'
if ( not os.access(vpxDll,os.F_OK) ):
print("WARNING: Invalid vpxDll path")
cdll.LoadLibrary( vpxDll )
vpx = CDLL( vpxDll )
eyeTime = c_double();
eyeTimePointer = pointer(eyeTime)
eyeA = self.arrington.EYE_A;
eyeDataTime = vpx.VPX_GetDataTime2(eyeA,eyeTimePointer)
outputString = 'eyeDataTime %f eyeTime %f' % (eyeDataTime, eyeTime.value)
print outputString
Streaming data with onNetwork Ryan Vizard 2 05-16-2013 06:47 AM
data lose psykoko Vizard 3 12-16-2010 08:08 PM
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 04:49 PM
Arrington - Ethernet ViewPoint Client jaclyn.bill Vizard 3 10-23-2009 10:43 AM
