Old 03-12-2014, 03:58 AM
ptjt255 ptjt255 is offline
Executable file exiting
I have created an executable version of some code but when I try and run it, it starts to load and then just exits - do you know why this might be happening?
Old 03-12-2014, 04:33 AM
I have the run code with the console visible and attach the error that I'm getting. I have numpy installed on the PC that I'm creating the exe file on and the exe file works on this PC but as soon as I try and run the exe file on any other machine that doesn't have numpy installed, I get the attached error message.
Old 03-12-2014, 07:30 AM
If a file is not automatically included in the executable you can manually add it in the second step of the publish wizard.
Old 03-12-2014, 08:26 AM
Thanks Jeff, I think I knew that somewhere in the depths if my memory from a similar issue a few years ago.
Unfortunately, in this instance adding the missing files hasn't worked.
I have tried just running the code that seems to be causing the problems:
C:\Program Files\WorldViz\Vizard30\python\numpy\_int_.py
and I'm getting the following error:
File "<string>", line 1, in ?
File "C:\Program Files\WorldViz\Vizard30/python\viz.py", line 14, in ?
import vizmat
File "C:\Program Files\WorldViz\Vizard30/python\vizmat.py", line 3, in ?
from random import random
File "random\__init__.py", line 3, in ?
from mtrand import *
File "numpy.pxi", line 74, in mtrand
File "C:\Program Files\WorldViz\Vizard30\python\numpy\__init__.py", line 37, in ?
import testing
File "C:\Program Files\WorldViz\Vizard30\python\numpy\testing\__ini t__.py", line 3, in ?
from numpytest import *
File "C:\Program Files\WorldViz\Vizard30\python\numpy\testing\numpy test.py", line 19, in ?
from numpy.distutils.exec_command import splitcmdline
File "C:\Program Files\WorldViz\Vizard30\python\numpy\distutils\__i nit__.py", line 6, in ?
import ccompiler
File "C:\Program Files\WorldViz\Vizard30\python\numpy\distutils\cco mpiler.py", line 6, in ?
from distutils.ccompiler import *
File "distutils\__init__.py", line 6, in ?
import ccompiler
File "distutils\ccompiler.py", line 7, in ?
from distutils import ccompiler
ImportError: cannot import name ccompiler
** ERROR: Failed to initialize python
Old 03-12-2014, 01:58 PM
It's best to trigger the code using numpy while compiling the executable. Then, the files that Vizard needs to run the executable will be compiled in the executable. You can also add files manually, but chances are you're missing out on one or two 'obscure' files (a .dll file).
Old 03-13-2014, 04:41 AM
Thumbs down
Thanks Frank.
I have tried everything, including adding the missing files and the executable still isn't working, although the error in the console has now changed to the attached.
Any other thoughts??
Many thanks.
Old 03-13-2014, 10:59 AM
I need to start running this code on Monday, so I'm getting a little nervous! Any chance that I can send it to you Jeff to convert to an exe?
Many thanks.
Old 03-13-2014, 01:21 PM
mspusch mspusch is offline
Hi ptjt255,
which license of Vizard are you using / do you own?
If it's a Vizard LITE, there are some restrictions about what an executable can do and which modules can be included.
All best,
Matthias
Old 03-14-2014, 01:32 AM
Hi Matthias,
I'm using a development licence.
Old 03-18-2014, 02:01 AM
I tried publishing a simply numpy example with Vizard and it worked fine. Can you reduce your code to the smallest example possible that reproduces the issue when published? Perhaps reduce it to some numpy code or even import statements related to that library and then post that here.
Closing of an imported .py file Uttama_vizard Vizard 2 05-04-2010 07:18 AM
problems with output to a text file within executable Saz Vizard 1 07-01-2009 12:01 PM
executable file with avatars incorrectly displayed aa-chris Vizard 2 11-03-2008 11:28 AM
File Management Uttama_vizard Vizard 2 07-01-2008 10:44 AM
Writing text files with executable adimov Vizard 1 03-21-2008 04:21 PM
