Old 02-25-2009, 06:30 AM
mrvr mrvr is offline
array problem
Hello!
I have made a playlist of songs, which in fact is an array, and I am trying to play the songs by using a for loop (I want to have constantly music at the background).
The problem is that it plays all the songs at once and as I can understand a timer that expires very quickly (I use this timer for the joystick) is responsible for that. I think I have to use another timer, but I have no idea what expiration time it should have, how many repeats, when to start it etc.
Can you give me any suggestions before I send my code?
Maria
Old 02-25-2009, 10:41 AM
Here is an example script that uses the viztask module to loop through a playlist of songs. Let me know if anything is unclear.
import viztask
PLAYLIST = ['crash.wav','BOING!.WAV','quack.wav']
def PlayMusicTask(songs):
	"""Task that loops through a playlist of songs"""
	#Preload all songs
	songCycle = viz.cycle([ viz.addAudio(filename) for filename in songs ])
	#Loop indefinitely through song list
	while True:
		#Play next song
		song = songCycle.next()
		song.play()
		#Wait for song to end
		yield viztask.waitMediaEnd(song)
#Schedule music task
viztask.schedule( PlayMusicTask(PLAYLIST) )
Old 02-25-2009, 04:46 PM
Thanks for the quick reply (you've saved me a lot of time!)
The only unclear thing is the following line:
It will load the songs as it is or I have to change something? (ie replace the "filename" with the first (actual) filename in songs?)
I also met another problem. I had these errors when I run the code:
File "C:\Program Files\WorldViz\Vizard30\python\viztask.py", line 685, in _onupdate
self._tasks = [ t for t in self._tasks if not t.update() ]
File "C:\Program Files\WorldViz\Vizard30\python\viztask.py", line 652, in update
val = self.__stack[-1].next()
File "museum.py", line 78, in PlayMusicTask
songCycle = viz.cycle([ viz.addAudio(filename ) for filename in songs ])
File "C:\Program Files\WorldViz\Vizard30/python\viz.py", line 7524, in addAudio
return VizAudio(_ipcSend(_VIZ_ADDAUDIO,0,0,fileName,0.0,0 .0,0.0,0.0),**kw)
TypeError: message must be a string
Old 02-26-2009, 12:18 PM
Did you get that error by running the exact code I posted?
That line of code creates a cycle of audio objects from the file names. All you have to change is the PLAYLIST variable to contain all the filenames of songs you want to play.
Old 02-27-2009, 06:25 PM
It was the exact code! The only different thing was the PLAYLIST, where I had replaced the sounds with my songs :-)
Old 03-02-2009, 09:21 AM
So it wasn't the exact code? I'm assuming you incorrectly defined the PLAYLIST variable. I can't provide anymore help unless you post the code you are using.
Old 03-03-2009, 03:35 AM
You were right. I fixed the problem.
Thanks a lot for your help and time!
Old 03-07-2014, 07:34 AM
NicoleVR NicoleVR is offline
Only cycle through once?
Hello, the code you helped with here has a loop to indefinetly loop through the songs. What if i want the loop to go through each element in the array only once? is there a way to detect that?
Nicole
Old 03-10-2014, 09:20 PM
Since you're not going to cycle through the songs you could use a standard list and a for loop:
#Preload all songs
songList = [ viz.addAudio(filename) for filename in songs ]
for song in songList:
	song.play()
A Little Programming Problem with MultiDimensional Arrays shivanangel Vizard 2 04-25-2007 12:21 PM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
problem with female animations vmonkey Vizard 1 10-07-2005 10:36 AM
Copy objects in an array to another array Johannes Vizard 3 04-29-2005 02:37 PM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 04:22 PM
