Tracking multiple LED's
Hi, Im new to Vizards and I'm quite confused about what is possible and what is not, so I got a few questions.
Is it possible to track multiple LED's? How does it work? can you give me some quickly explanation about it? Do I have to build a tracker for each LED as I do to track only one LED? Was this discussed before? |
Also, another question that came up was, Im trying to track and LED inside a Lab, do I have .dae loaded and when I rotate the map 90 degrees in Yaw of the map, it appears to be 90 degrees pitch of the helmet that Im using... how can I make the Yaw of the map be the same as the helmet?
http://docs.worldviz.com/vizard/#WorldViz_PPT_VRPN.htm Quote:
| Trouble Tracking 2 LEDs Independently | smurray | Precision Position Tracker (PPT) | 0 | 10-13-2009 11:03 AM |
| trouble tracking multiple lights | Vkathrynr | Precision Position Tracker (PPT) | 2 | 08-26-2009 12:07 PM |
| tracking with multiple LEDS | dan12345 | Precision Position Tracker (PPT) | 7 | 04-02-2008 10:44 PM |
| How to load multiple LEDs into PPT | ruddle | Precision Position Tracker (PPT) | 3 | 06-20-2007 12:21 AM |
| Identity of multiple leds | Jerry | Precision Position Tracker (PPT) | 1 | 06-22-2006 10:07 AM |
