Making a HD Complete Character blink
Hi all,
I'm trying to get a HD Complete Character to blink. HD Complete Characters have bones for facial expressions, so I thought that I had to control the bones of the eye lids to make them blink. However, I have difficulties getting a HD Complete Character to blink with using the eye lid bones. See the code below for my code. I thought rotating either the EyeBlinkTop or EyeBlinkBottom bones should do the trick, however it does not. Any help would be greatly appreciated! Code:
avatar = viz.add('vcc_male2.cfg', pos = [0,.15,.5], euler = [180,0,0])
blinkLeft = avatar.getBone('Bip01 LEyeBlinkTop')
blinkRight = avatar.getBone('Bip01 REyeBlinkBottom')
blinkLeft.lock()
blinkRight.lock()
def onKeyDown(key):
eulerLeft = blinkLeft.getEuler(viz.AVATAR_LOCAL)
eulerRight = blinkRight.getEuler(viz.AVATAR_LOCAL)
if key in 'qQ':
eulerLeft[0] += 1
eulerRight[0] += 1
elif key in 'aA':
eulerLeft[0] -= 1
eulerRight[0] -= 1
elif key in 'wW':
eulerLeft[1] += 1
eulerRight[1] += 1
elif key in 'eE':
eulerLeft[1] -= 1
eulerRight[1] -= 1
elif key in 'sS':
eulerLeft[2] += 1
eulerRight[2] += 1
elif key in 'dD':
eulerLeft[2] -= 1
eulerRight[2] -= 1
blinkLeft.setEuler(eulerLeft, viz.AVATAR_LOCAL)
blinkRight.setEuler(eulerRight, viz.AVATAR_LOCAL)
viz.callback(viz.KEYDOWN_EVENT,onKeyDown)
Most of the animations included with the HD characters have blinking included. You could print out the bone values with an animation running to see how the values change over time. To create a blinking effect as natural as the animations the bone rotations would probably require a non linear function.
Hi Jeff,
Sounds like a good idea! However, I've tried to print the eulers (also tried quaternions) of the eye related bones, while running one of the standard animations and was unable to detect changes in eulers (or quaternions) of those bones. So I don't know how the HD character blinks during the standard animations. In its cfg file, no blink morph is specified, so blinking is not accomplished through applying a moprh. Any suggestions? Code:
avatar = viz.add('vcc_male2.cfg', pos = [0,.15,.25], euler = [180,0,0])
avatar.state(1)
boneList = []
for bone in avatar.getBoneList():
if 'Eye' in bone.getName() and not (('brow' in bone.getName()) or 'Nub' in bone.getName()):
boneList.append(bone)
def printInfo():
for bone in boneList:
print bone.getName(), bone.getEuler()
vizact.ontimer(viz.FASTEST_EXPIRATION, printInfo)
Okay, I'm pretty sure the eyelids are not moved by bones. I've tried recording a little piece of one of the standard animations of the sample HD character, with blinking included. Uncomment vizact.onexit(saveTrackingData) to enable saving. Warning: the resulting file gets big (for a .log file) fast:
import cPickle
avatar.state(1)
boneList = []
boneNameList = []
boneNameList.append(bone.getName())
global bone_info, total_info
bone_info = []
total_info = []
def updateBoneInfo():
bone_info.append(bone.getName())
bone_info.append(bone.getEuler())
total_info.append(bone_info)
bone_info = []
vizact.ontimer(viz.FASTEST_EXPIRATION, updateBoneInfo)
BONE_DATA = open("Recording_of_bones.log", 'w+')
def saveTrackingData():
global total_info
cPickle.dump(total_info, BONE_DATA)
BONE_DATA.flush()
BONE_DATA.close()
#vizact.onexit(saveTrackingData)
import viztask
import cPickle
from collections import deque
boneList = []
boneNameList = []
bone.lock()
BONE_DATA = open("Recording_of_bones.log", 'r')
def setBones():
total_info = deque(cPickle.load(BONE_DATA))
yield viztask.waitDraw()
while len(total_info) > 0:
line = line = deque(total_info.popleft())
while len(line) > 0:
boneName = line.popleft()
boneOrientation = line.popleft()
if boneName in boneNameList:
index = boneNameList.index(boneName)
boneList[index].setEuler(boneOrientation)
print 'bone not found on character!'
def onKeyDown(key):
if key in 'bB':
viztask.schedule(setBones)
Hi Frank,
Please try the quick example which shown the idea for how to animating a blinking eye. Actually it will need to move the bones positions more rather then just the orientations. But the batter way for doing this will be animate the bones with matrix which include both the positions and rotations. Hope this helps. |
Hi Frank,
For your information, the blink animation at my example which I post previously was played back at a slowdown speed for showing the idea. Here is another example which will playback the blink animation at normal speed. Cheers, |
Hi Kevin,
Thank you very much for your example! I managed to get the animation I wanted. Never thought about the position of the bones (and never worked with matrices in Vizard), but it worked like a charm! Cheers, Frank |
Just updated the code. Old version:
def playback():
def subTask():
for bones in boneObjList:
bones.lock()
currentBone = 0
for mat in boneMatList:
boneObjList[currentBone].setMatrix(mat, viz.ABS_PARENT)
yield None
if currentBone+1 == len(boneObjList):
currentBone = 0
currentBone += 1
bones.unlock()
viztask.schedule( subTask() )
# Press the space key for playing back the blink animation
vizact.onkeydown(' ', playback)
def playback():
def subTask():
bones.lock()
for i, mat in enumerate(boneMatList):
boneObjList[i % len(boneObjList)].setMatrix(mat, viz.ABS_PARENT)
bones.unlock()
| Tags |
| blinking, hd complete characters |
| Custom head on HD Complete Character | Frank Verberne | Vizard | 3 | 06-18-2013 06:18 PM |
| Moving, blinking eyes for Complete Character Set | Frank Verberne | Vizard | 4 | 09-14-2012 06:42 AM |
| making a Complete Character Set character speak | Frank Verberne | Vizard | 4 | 05-25-2012 09:47 PM |
| New Complete Character morph targets for facial animation? | Deltcho | Vizard | 2 | 07-26-2010 05:26 PM |
| How to make avatar's eyes to blink when speaking | michelcm3 | Vizard | 12 | 01-15-2008 09:48 AM |
