Avatar walks too slow
I've been trying to make a avatar walk inside of a room, to make the avatar look like a normal person I used the function setscale, which makes it bigger. The problem is when I use vizact.walkto, the avatar walks really slow. The answer to why is walks like that its easy, I made the avatar look bigger but when it comes to move it moves as if it had his original size. How do I make the avatar walk faster like a normal person?? thanks in advance |
Is the room scaled to the correct size? You can quickly check the dimensions of the room's bounding box by loading it in Inspector.
You can use the walkSpeed argument to change the speed: Code:
vizact.walkTo(pos=[0,0,15],walkSpeed=3) |
yes, thank you, it works
| Avatar & Motion Capture Interface | Angie | Vizard | 1 | 08-05-2010 06:17 PM |
| avatar scale and link.setpos conflict? | sircedric4 | Vizard | 0 | 09-29-2009 07:48 AM |
| Collision of an avatar with a quad | Frank Verberne | Vizard | 8 | 06-04-2008 09:44 AM |
| Looking through the eyes of an avatar | Frank Verberne | Vizard | 2 | 04-01-2008 05:52 AM |
| How to make avatar's eyes to blink when speaking | michelcm3 | Vizard | 12 | 01-15-2008 08:48 AM |
