Old 09-13-2013, 07:12 AM
kerscha kerscha is offline
Exclamation Collision in Corner Cave
I have looked everywhere for a solution to my problem and have been unsuccessful. I need help to determine why my collision does not work inside of my Corner Cave. When I don't use the trackers (meaning outside of the Cave), collision works just fine. But as soon as I go into the Cave and turn on the trackers, it no longer works.
Inside of my viztracker file, I have the following bit of code:
viz.collision(viz.ON)
def onCollision(info):
print "COLLIDED"
viz.callback(viz.COLLISION_EVENT, onCollision)
Every time I run the program, it prints a whole slew of "COLLIDED" lines, meaning that the collisions are registering. However, when I walk into objects using the Wand's Joystick, I just walk right through them. PLEASE help me, as I have looked everywhere and no such solution exists. Thanks in advance!
Old 09-16-2013, 06:46 AM
Kevin Chiu Kevin Chiu is offline
Can you provide your viztracker file for us to have a look on it?
It is still hard to say that what is the exact problem form the descriptions.
Thanks.
Kevin
Old 02-14-2014, 11:10 PM
raj raj is offline
hi
i m using with Architectural interactive for VR
now mesh collision not working in corner cave mode...not even with world viz examples.
i m attaching tracker file for Reference
reply
regards
raj
Old 04-22-2015, 11:54 PM
adhocdown adhocdown is offline
Bump
I'm curious to know the resolution to this problem as I am experiencing the same complication. The only difference is that I am using PPT.
Given that two different tracking systems are experiencing this problem, I think this might be an issue with Vizard's collision handling.
It's very frustrating and I've tried devising numerous workarounds.
Old 04-23-2015, 01:07 PM
Following up on this this thread.
cave, collision, tracker
Collision Exception jassel41 Vizard 2 11-09-2010 06:08 PM
Collision and avatar animation shahramy Vizard 2 10-27-2010 12:47 AM
[New here] Cave joy navigation esuna114 Vizard 2 06-11-2010 05:36 PM
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 11:12 AM
Collision with child nodes rubberpimple Vizard 4 09-17-2008 05:27 PM
