Old 07-08-2013, 09:45 AM
mape2k mape2k is offline
Inconsistent timestamp while logging
Hi all,
I have come across a problem concerning the timestamps in a log file that I want to use to monitor the position and view angle of a subject during an experiment.
At the beginning of the experiment, I am calling the logging function with vizact.ontimer(fs,function), with fs being the desired sampling frequency. When I use this method, I am not getting timestamps with equal time spans in the log file. It seems that the time spans vary about the given fs with +-10ms.
I am using datetime.datetime.now() to get the current time. Is there any other way of producing accurate time readings? I have read that datetime essentially uses time.time(), which is supposed to be the most accurate function in Python.
Here is an example for an fs = 10:
Timestamp, Position, View Angle
18:42:41:056,[0.000,1.820,-0.000],[-0.000]
18:42:41:166,[0.000,1.820,-0.000],[-0.000]
18:42:41:259,[0.000,1.820,-0.000],[-0.000]
18:42:41:368,[0.000,1.820,-0.000],[-0.000]
18:42:41:462,[0.000,1.820,-0.000],[-0.000]
18:42:41:556,[0.000,1.820,-0.000],[-0.000]
18:42:41:665,[0.000,1.820,-0.000],[-0.000]
18:42:41:758,[0.000,1.820,-0.000],[-0.000]
18:42:41:868,[0.000,1.820,-0.000],[-0.000]
18:42:41:961,[0.000,1.820,-0.000],[-0.000]
18:42:42:070,[0.000,1.820,-0.000],[-0.000]
18:42:42:164,[0.000,1.820,-0.000],[-0.000]
18:42:42:258,[0.000,1.820,-0.000],[-0.000]
Also, I am including a minimum working example:
from __future__ import division
import viztask
import os
import datetime
class myTimer():
	def __init__(self,number,dateFormat,timeFormat):
		self.nr = number
		self.dateFormat = dateFormat
		self.timeFormat = timeFormat
	def time(self):
		self.curDateTime = datetime.datetime.now()
		self.curTime = self.curDateTime.strftime(self.timeFormat)
		if self.timeFormat == '%H:%M:%S:%f':
			self.curTime = self.curTime[:-3]
		return self.curTime
logTime = myTimer(1,'%d.%m.%Y','%H:%M:%S:%f')
file = open('test.txt', 'w')
def posLogger():
	curAngle = viz.MainView.getEuler()
	curPos = viz.MainView.getPosition()
	file.write('%s,[%0.3f,%0.3f,%0.3f],[%0.3f]\n' %
	(logTime.time(),curPos[0],curPos[1],curPos[2],curAngle[0]))
# Start
fs = 10
print 1/fs
logTimer = vizact.ontimer((1/fs),posLogger)
Old 07-09-2013, 12:07 AM
sleiN13 sleiN13 is offline
The timer function probably will only be called when the vizard rendering loop is in its update phase.
This means if the timer was suppose to run out but vizard is busy with rendering the scene or other code, it has to wait untill that part is finished.
This restriction is a consequence of the python interperter lock and there probably isn't a good solution for you problem because of it.
Also I believe that the time.clock() function is more precise it ofcourse doesn't give a date.
Old 07-09-2013, 11:48 PM
Thanks for your reply!
Do you think the problem might also be reduced when I call the timer function in a new thread (i.e. viz. director(function))? Or would the vizard rendering loop still delay the output?
Old 07-10-2013, 09:47 AM
For high resolution timing values, you should use either viz.tick() or time.clock(). These functions will provide the number of seconds since the application started. If you need a high resolution representation of the actual time, then you can capture the current time at the beginning of your script and then add on the high resolution seconds to it at runtime. Here is an example:
import datetime
# Get starting time and tick
startTime = datetime.datetime.now()
startTick = viz.tick()
def LogTime():
	# Add elapsed seconds to starting time
	curTime = startTime + datetime.timedelta(0,viz.tick()-startTick)
	print curTime.strftime('%H:%M:%S:%f')
vizact.ontimer(0.1, LogTime)
Keep in mind that writing to a file in the main rendering loop can cause drops in your framerate. You might want to consider moving your file writing code to a different thread.
Old 07-15-2013, 06:03 AM
Thank you farshizzo for your detailed reply! I will try out your code as soon as possible and report back on the matter.
Head tracking logging & realtime data tmcw Vizard 2 08-18-2007 10:31 AM
