Old 04-14-2009, 04:07 AM
Joran Joran is offline
Send a message via Yahoo to Joran
Getting data from a render texture
I want to get the data from a depth texture. I use the following command to create the texture:
depthtex = viz.addRenderTexture(format = viz.TEX_DEPTH, width = 8, height = 8)
And somewhere else I attach this texture to a viz.RENDER_DEPTH render node. Is there a way to get the data from this texture in python?
Greetings, Joran.
Old 04-16-2009, 10:30 AM
There is currently no built-in way to retrieve the data from a render texture. You could create a modifier plugin that attaches a post draw callback to the underlying osg::CameraNode object. From the callback you should be able to read the pixels from the texture into memory.
Do you need the data for real-time purposes (i.e. every frame)? If not, you can workaround the problem by rendering the depth texture to the screen and then capturing the screen to a file.
Old 04-17-2009, 12:24 AM
It is for real time processing. Is there any chance this functionality will be added in the future to Vizard?
Otherwise I will have to make that plugin. I am not looking forward to that.
Old 06-03-2013, 02:11 AM
I am revisiting this 'problem'. The version using a plugin did work (I need to recompile the plugin again). But now I saw the <multimedia:image>.saveToBuffer() method. It looks very useful. I still have:
And i can now save it to a buffer with:
depthtex.saveToBuffer('<raw>')
But this buffer then contains an 8 bit z-buffer. When I change my texture format to viz.TEX_DEPTH_32, I get the error message:
error pixelFormat = 81a7
** ERROR: Texture does not contain image data, cannot save to buffer
I am almost where I want to be. Is there some way to save a 16 bit or 32 bit z-buffer? Or maybe could the support for it be added to saveToBuffer?
Greetings, Joran.
writing joystick position to a data file Saz Vizard 3 12-17-2008 05:18 AM
Translating a texture and its Alpha shivanangel Vizard 5 12-02-2008 04:52 PM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 08:48 AM
how I can get my texture to appear exactly as is defined mspusch Vizard 1 04-23-2005 12:12 PM
