Old 05-07-2013, 07:02 PM
AndyGuatemala AndyGuatemala is offline
Train Tracks
I am trying to create a train simulation in which the view point moves over a set loop which can be changed. I coded the loop using viztask.schedule but now I am trying to put down a track that is there before the simulation runs. I tried doing it by running the simulation and saving the path the viewpoint takes and eventually using that list to make the lines. However, I feel like there has to be a better way of doing this. Plus, the tracks needs to be on the ground, not on the same level as the viewpoint. Any advice?
Old 05-09-2013, 04:08 PM
Can you just pre-generate the tracks and save it out to a file? Or does the path change every time you run the script? Unless I am misunderstanding something, what you are currently doing sounds reasonable.
Old 05-10-2013, 07:12 AM
I can. I just figured there might be a better way to do it.
lines, loop, traintracks
Animation Tracks.... k_iwan Vizard 2 03-26-2007 05:52 PM
