Old 04-26-2013, 11:31 AM
disbeat disbeat is offline
Spheric skydome for panorama
I am wondering if anyone as tried to use a spheric environmental map instead of the cubic one refered in the help.
Marco Simões
Old 05-06-2013, 10:57 AM
Vizard comes with a few models that use a panoramic 2d image to create a sky dome, instead of a cube map. Have a look at the sky_day.osgb and sky_night.osgb models in the resources folder. Both those models were created with 3ds Max.
Old 05-07-2013, 04:02 AM
Hi farshizzo,
Thank you a lot for your reply!
I looked into those models, but still I'm having troubles achieving my goal.
I cannot import osgb files into 3ds max (I think...) so I tried to do some attempts to texture over those model directly in vizard.
I could not get the result I was hoping for...
I'm attaching one example of panorama I'm trying to use. Could you give me some feedback on how to proceed?
Thank you a lot!
-- Marco Simões
Old 05-09-2013, 10:10 AM
You will need to create your own model with the proper UV coordinates.
The sample image you provided looks like it can be applied to a standard cylinder. Try the following code:
import vizshape
viz.fov(60)
panorama = viz.add('panorama.jpg')
cyl = vizshape.addCylinder(radius=100,height=200,slices=100,flipFaces=True,top=False,bottom=False)
cyl.texture(panorama)
viz.link(viz.MainView,cyl,mask=viz.LINK_POS)
Skydome texture problem theuberk Vizard 2 01-18-2008 06:56 AM
