"Could not find plugin to read objects" error?
Hey guys,
I have a problem where I am trying to load a character into Vizard 4.0, but whenever I try my character is extremely distorted as you can see by the image ![]() I get the error message Warning: Could not find plugin to read objects from file "<none>". It appears 4 times. Any idea what the error could be? |
Does anybody Know the issue?
I was able to fix the textures but the mesh still comes out wonky. |
It might be that your skeleton or animation uses a different coordinate system (different Up axis).
Hi Jfenster,
You may be doing something wrong in your export process. Your screenshot looks similar to what tends to happen when a mesh is loaded onto an incorrect skeleton. You may also have a typo somewhere in your CFG. Can I get a look at your Max file and exported avatar? You can upload a zip of them here: http://www.worldviz.com/support/upload |
| Error: Could not find plugin to read objects from file | jde | Vizard | 3 | 02-15-2012 01:49 PM |
| Semi-circle array containing target and distractor objects | ptjt255 | Vizard | 3 | 08-04-2009 03:09 AM |
| Error loading plugin | djdesmangles | Vizard | 2 | 10-02-2008 07:13 AM |
| Could not find plugin to load objects... | halley | Vizard | 1 | 05-30-2006 11:01 AM |
