Old 02-14-2013, 09:27 AM
nabrahamson nabrahamson is offline
Toggling between 2D and 3D on the fly.
Is it possible to switch between having the Quadbuffer functionality turned on and off on the fly while running a vizard script?
Old 02-15-2013, 11:09 AM
Yes, you can use the viz.MainWindow.stereo command to change the stereo mode at runtime. Here is a sample script that toggle quad buffer stereo using the spacebar:
viz.go(viz.QUAD_BUFFER)
viz.add('gallery.osgb')
def ToggleStereo():
	if viz.MainWindow.getStereo() & viz.QUAD_BUFFER:
		viz.MainWindow.stereo(0)
		viz.MainWindow.stereo(viz.QUAD_BUFFER)
vizact.onkeydown(' ',ToggleStereo)
Old 02-19-2013, 08:42 AM
Thank you. This saved me a bit of time.
