				Multi-Texturing Issues
			We are experimenting with Vizard 4 Trial Version. We are implementing Advanced Shaders. While Implementing them we are facing problems. For shaders we need to map multiple textures & cubemaps over the object. Vizard only permits 4 textures/Cubemaps. We can apply those textures on units (layers) 0, 1,2 & 3; but not on units 4,5,6 etc. Are these issues because of trial version? If Vizard only permits 4 textures then how to apply more than 4 textures?
			The Trial version of Vizard does not impose any limitations on the number of textures you can apply to an object. What kind of graphics card do you have? Are you using a fragment shader to blend the multiple textures? I know most nVidia drivers only support 4 texture units when using the fixed function pipeline to combine the textures. However, depending on the driver, a lot more units are supported when using a fragment shader to combine the textures.
	Run the following script. The first number it prints out will be the maximum number of fixed function texture units supported by your driver. The second number will be the maximum number of fragment shader texture units supported. Code:
print viz.getOption('gl.max_texture_units')
print viz.getOption('gl.max_texture_image_units')
			I am using this method to apply textures & shader
tex0 = viz.addTexture('image0.jpg')
tex1 = viz.addTexture('image1.jpg')
tex2 = viz.addTexture('image2.jpg')
tex3 = viz.addTexture('image3.jpg')
node3d.texture(tex0,node = 'node_name', unit = 0)
node3d.texture(tex1,node = 'node_name', unit = 1)
node3d.texture(tex2,node = 'node_name', unit = 2)
node3d.texture(tex3,node = 'node_name', unit = 3)
vertCode = """
fragCode = """
uniform sampler2D texture0;
uniform sampler2D texture1;
uniform sampler2D texture2;
uniform sampler2D texture3;
varying .......
void main()
Thanks !!  |
			for
************************************************** ********** 4 32 ** Load Time: 0.18 seconds  |
			Your driver should support up to 32 textures when using a fragment shader. Try running the following script:
IMAGES = [ 'images/tile_grass.jpg'
			,'images/tile_gray.jpg'
			,'images/tile_slate.jpg'
			,'images/tile_stone.jpg'
			,'images/tile_wood.jpg'
quad = viz.addTexQuad(pos=(0,1.8,2))
for x,name in enumerate(IMAGES):
	tex = viz.addTexture(name)
	quad.texture(tex,unit=x)
	quad.apply(viz.addUniformInt('tex{}'.format(x),x))
frag = """
uniform sampler2D tex0;
uniform sampler2D tex1;
uniform sampler2D tex2;
uniform sampler2D tex3;
uniform sampler2D tex4;
void main()
	vec2 uv = gl_TexCoord[0].st;
	if(uv.x > 0.8) {
		gl_FragColor = texture2D(tex4,uv);
	} else if(uv.x > 0.6) {
		gl_FragColor = texture2D(tex3,uv);
	} else if(uv.x > 0.4) {
		gl_FragColor = texture2D(tex2,uv);
	} else if(uv.x > 0.2) {
		gl_FragColor = texture2D(tex1,uv);
	} else {
		gl_FragColor = texture2D(tex0,uv);
quad.apply(viz.addShader(frag=frag))
| Tags |
| layers, multi texturing, textures |
| Multi User Environment | moneim230 | Vizard | 5 | 05-17-2011 06:56 PM |
| Issues with Calibration Rig | adam.rodgers | Precision Position Tracker (PPT) | 2 | 12-02-2008 11:13 PM |
| Read file....many issues | Uttama_vizard | Vizard | 9 | 07-08-2008 03:16 PM |
| Video Texturing | cheezus69 | Vizard | 2 | 04-14-2008 04:26 AM |
| Mirror issues | Frank Verberne | Vizard | 2 | 04-08-2008 11:37 AM |
