Old 12-11-2012, 08:51 AM
asdf asdf is offline
Export/Save state of level
I want to import the level, change some of the loaded objects and save the level again.
Is there some kind of best practise?
If there isn't i would save all objects in some kind of XML file or (if there is some kind of "masterarray with all objects") serialise them with pickle for python.
Any suggestions regarding these ideas?
The Question is somewhat related to this question, except that i don't really care about the exported format, as long as i can import it again.
Old 12-11-2012, 11:36 AM
Can you explain how the objects are changing? Perhaps you can just save information to a text file about how they changed.
Old 12-11-2012, 03:57 PM
You can export the scene to the osg format and load it later. See the last post in this thread.
Old 12-18-2012, 03:25 AM
Thanks that will work perfect.
Load Scene (including objects) interact with them and safe the Scene again. I could use a txt file or XML, but if I can directly save as osg, it's much easier.
'VizChild' object has no attribute 'state' nat_bor Vizard 3 03-12-2011 12:51 AM
rendering level shahramy Vizard 1 07-26-2010 01:12 PM
Check if an avatar has a state "123" Josh Vizard 1 04-06-2010 02:11 PM
Level of Detail envisC Vizard 2 10-22-2009 01:07 PM
On Screen Keyboard betancourtb82 Vizard 14 10-03-2006 01:38 PM
