Old 11-20-2012, 10:22 AM
blaise blaise is offline
How to control ive or osg animation?
Dear All
The animation I exported from 3DSmax into ive files run in vizard loop mode. How can I control that animation?
I would need to pause/ slow down or speed it up.
Many thanks in advance.
Old 11-21-2012, 10:09 AM
There are a number of get and set commands that can be used with imported animations. The following example shows how to set the speed, state, and loop mode on one of the animations included in the piazza_animations.osgb file:
viz.setMultiSample(8)
viz.fov(60)
# Add piazza model
model = viz.addChild('piazza.osgb')
# Add piazza animations
animations = viz.add('piazza_animations.osgb')
# Create avatar parented to walk animation
avatar_path = animations.getChild('walk')
avatar = viz.addAvatar('vcc_male2.cfg')
avatar.setParent(avatar_path,node='walk')
avatar.state(2)
#set animation time, speed, and loop mode
avatar_path.setAnimationTime(10.0)
avatar_path.setAnimationSpeed(1.5)
avatar_path.setAnimationLoopMode(0)
#toggle between pause/play
vizact.onkeydown(' ',avatar_path.setAnimationState,viz.TOGGLE)
viz.MainView.move([0,0,-7])
Old 11-22-2012, 06:26 AM
Thank you Jeff!
I understand the script works only for osg animations. Is there a way to control animations on ive files?
Old 11-26-2012, 12:13 PM
It will work with ive. If you are exporting these models yourself we recommend exporting to osgb, the newer and preferred version of the compiled osg format.
control animation on ive or wrl files? Darkmax Vizard 8 07-17-2012 12:13 PM
Clarification on CAL3D Avatar Animation in Vizard shivanangel Vizard 2 11-22-2010 07:16 AM
adding more than 1 action for avatar animation slider control yak Vizard 0 07-21-2009 11:22 AM
Animation Tracks.... k_iwan Vizard 2 03-26-2007 05:52 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 02:11 PM
