Old 09-12-2012, 08:42 AM
pwsnow pwsnow is offline
Picking up Vizard Objects on mouse down with collisions
I'm trying to pick up vizard objects using a vizshape sphere as an end effector.
Because I have multiple objects I'm using onCollideBegin to grab the objects when the end effect collides with the object to be picked up. This work fine but the end effector doesn't let go of the object and it is automatic, however I want to be able to pick up objects when I touch them and hold them as long as the left mouse button is pressed. Releasing the object once the left mouse button is released. I have the below code in my updateview method:
def onCollideBegin(e):
		#while vizact.whilemousedown(viz.MOUSEBUTTON_LEFT):
			if e.obj1 == sphere:
				if e.obj2 == cube:
					link = viz.grab(sphere,cube)
					#viz.playSound( 'crashNew.wav' )
					libc.haDeviceSendString(dev, "set myDamper enable",response)
				if e.obj2 == cube2:
					link = viz.grab(sphere,cube2)
				if e.obj2 == ball:
					link = viz.grab(sphere,ball)
	viz.callback(viz.COLLIDE_BEGIN_EVENT,onCollideBegin)
	#vizact.whilemousedown(viz.MOUSEBUTTON_LEFT,onCollideBegin)
	def onCollideEnd(e):
				if e.obj2 == cube:
					link = None
					libc.haDeviceSendString(dev, "set myDamper disable",response)
				if e.obj2 == cube2:
					link = None
				if e.obj2 == ball:
					link = None
	viz.callback(viz.COLLIDE_END_EVENT,onCollideEnd)
	vizact.onmousedown(viz.MOUSEBUTTON_LEFT,onCollideBegin)
	vizact.onmouseup(viz.MOUSEBUTTON_LEFT,onCollideEnd)
	#vizact.whilemouseup(viz.MOUSEBUTTON_LEFT,onCollideEnd)
Because def onCollideBegin/End is using an event how would I "wrap up" these two methods with the mouse down/up?
Many thanks.
Old 09-13-2012, 03:49 PM
Here's an example that uses viz.phys.intersectNode to determine if the hand and object are intersecting. If they are intersecting and the mouse event occurs the object will be grabbed:
import vizmat
import viztracker
viz.setMultiSample(4)
viz.fov(60)
piazza = viz.add('piazza.osgb')
#Add crates marker for participant to walk to
crate1 = viz.addChild('crate.osgb',pos=[-0.3,0.3,4],scale=[0.6,0.6,0.6])
crate2 = crate1.clone(pos=[0.35,0.3,4],euler=[5,0,0],scale=[0.6,0.6,0.6])
crate3 = crate1.clone(pos=[0.3,0.9,4.1],euler=[-5,0,0],scale=[0.6,0.6,0.6])
arrow = viz.addChild('arrow.wrl',scale=[0.3,0.3,0.3])
#enable physics and apply shapes
viz.phys.enable()
piazza.collideMesh()
crate1.collideBox()
crate2.collideBox()
crate3.collideBox()
arrow.collideBox()
arrow.disable( viz.DYNAMICS )
arrow.disable( viz.PHYSICS )
#Link arrow to mousetracker
viewTracker = viztracker.Keyboard6DOF()
viewlink = viz.link( viewTracker, viz.MainView )
viewlink.preTrans([0,1.5,0])
tracker = viztracker.MouseTracker()
trackerlink = viz.link( tracker, arrow )
trackerlink.postTrans([0,0,-5])
closest = None
def updateClosest():
	global closest
	list = viz.phys.intersectNode( arrow )
	if list != []:
		for object in list:
			if object == piazza:
				list.remove(piazza)
		closestDistance = 999999
		arrowPos = arrow.getPosition()
		for object in list:
			distance = vizmat.Distance(arrowPos,object.getPosition())
			if distance < closestDistance:
				closest = object
				closestDistance = distance
		closest = None
vizact.onupdate(viz.PRIORITY_DEFAULT,updateClosest)
link = None
grabbedObject = None
def onMouseDown():
	global link, grabbedObject
	if closest is not None:
		link = viz.grab( arrow, closest )
		grabbedObject = closest
def onMouseUp():
	if grabbedObject is not None:
		link.remove()
vizact.onmousedown( viz.MOUSEBUTTON_LEFT, onMouseDown )
vizact.onmouseup( viz.MOUSEBUTTON_LEFT, onMouseUp )
Old 09-17-2012, 03:02 AM
Excellent, works like a charm.
Many thanks again!
Trouble picking text3d objects Salvar Vizard 4 12-01-2010 04:07 PM
Pivot points for child objects in Vizard with 3ds Max Gladsomebeast Vizard 0 09-19-2006 12:21 PM
