Old 04-21-2010, 08:52 AM
Darkmax Darkmax is offline
control animation on ive or wrl files?
When i export my models with animation in wrl or ive files the animation runs in vizard in loop mode, how can i control that animation.
For example i want to play it when i want or pause the animation in some point, instead of running always the animation like crazy.
Just to clarify what im doing to have these animations:
When i use animations of translation, rotation or scale i just export in ive or wrl, but when i need to use animations of vertices, i use vrml(wrl) also or the osg sequence from tools that come with the osg exporter for max to exported in ive.
Old 04-23-2010, 01:16 PM
Attached is a folder containing a plug-in and a python module that loads this plug-in to control OSG animations based on simple transformations(translation,rotation,scale). Also in the folder is an example script that uses the python module.
For controlling complex animations you can export to the Cal3D avatar format. In Vizard you could either play animations or animate between morph targets.
Old 04-26-2010, 07:39 AM
Wow thanks Jeff, this going to be very helpful with the animations of my project
Old 04-30-2010, 04:09 AM
TarkaDahl TarkaDahl is offline
Im having a similar problem i cant seem to stop an animating wrl file. im getting the artist who makes most of our models to use osg but we still get models from other artist as animating wrls.
Old 04-30-2010, 07:23 AM
Maybe there is another solution more elegant, but when i have a wrl model i import it in 3ds max then export it in a osg format
Old 04-30-2010, 02:43 PM
Thats what i would do but im not going to be the person running the program and they wont have 3d studio max or any other 3d package
Old 07-17-2012, 12:55 PM
Kyman2008 Kyman2008 is offline
i am having trouble loading this plug-in and using it with my .ive file....help!
Old 07-17-2012, 01:08 PM
however I am using vizard 4.0
Old 07-17-2012, 01:13 PM
Have a look at this post
adding more than 1 action for avatar animation slider control yak Vizard 0 07-21-2009 12:22 PM
How to edit the skin tones of the complete characters' cfg files? vEsotu Vizard 3 09-23-2008 01:07 PM
Animation Tracks.... k_iwan Vizard 2 03-26-2007 06:52 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 03:11 PM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 04:23 PM
