Old 04-18-2012, 12:34 PM
Lynnifer Lynnifer is offline
Getting Position
How can I find the absolute position in space of a 3d text object. I am using a 3d text "+" sign as a pointer in my program. It is attached to a parent node (handNode) which moves based on a motion tracker.
handNode = viz.add(viz.TEXT3D,'.')
#handNode.visible ( viz.ON )
handNode.color(1,0,0) # red
handNode.scale(.005, .005, .005)
pointer = handNode.add( viz.TEXT3D,'+')
#pointer.visible ( viz.ON )
pointer.translate(0, 0, 12)
pointer.color(1,0,0) # Red
pointer.scale(18, 18, 18)
Right now, I am using " pointer.get(viz.POSITION) " to get its position in 3d space. It can be seen in this statement of the program:
DaAngleBearing = self.findBearing( viz.get(viz.HEAD_POS), pointer.get(viz.POSITION) )
DaAnglePitch = self.findPitch(viz.get(viz.HEAD_POS), pointer.get(viz.POSITION) )
Right now, when I use print outputs to find what the program is doing, it looks like it's giving me the pointers position relative to another object, and that relative position is going into the statement above and being used to calculate the angle and pitch between head and pointer. I need to use the absolute position of the pointer. Any suggestions are appreciated.
Old 07-16-2012, 10:49 AM
DillonB DillonB is offline
pointer.getPosition(viz.ABS_GLOBAL) should give you the absolute position. Check out this tutorial: http://docs.worldviz.com/vizard/inde...orial_list.htm
Dynamic Position and Radius of Sphere hotshotiguana Vizard 1 03-23-2011 01:53 PM
Translate view from sensor position to lens position? Kaminski Vizard 4 03-09-2011 11:36 AM
writing joystick position to a data file Saz Vizard 3 12-17-2008 06:18 AM
default start position erchrastil Vizard 2 06-23-2008 09:15 AM
Avatar always returns in initial position pattie Vizard 2 08-31-2006 09:15 PM
