Old 08-12-2010, 01:14 AM
Andy Andy is offline
one panel over all windows
Hi, is it possible to show the vizinfo panel in front of all subwindows?
I have some subwindows and if I open the panel I can see it in all subwindows. Also the sub-windows mask the panel of the MainWindow.
A vizdlg panel is shown only on the MainWindow but it is mask by the subwindows.
My idea is to create a new subwindow, transparent without content only with the panel and then bring it in the front of all windows. Is it possible?
Old 08-16-2010, 04:41 PM
Your idea will work. The following code adds the info box only to a transparent window on top:
import vizinfo
info = vizinfo.add('Info box in transparent window')
info.translate(0.05,0.95)
info.alignment(vizinfo.UPPER_LEFT)
#don't add info box to MainWindow
viz.MainWindow.visible(0,viz.SCREEN)
#add a subwindow
subWindow = viz.addWindow()
subWindow.setPosition([0,1])
#dont' add info box here
subWindow.visible(0,viz.SCREEN)
#add a clearWindow that the info box appears in
clearWindow = viz.addWindow()
clearWindow.setClearMask(viz.GL_STENCIL_BUFFER_BIT)
clearWindow.setPosition([0,1])
clearWindow.setSize([1,1])
Old 10-06-2010, 06:25 AM
Hi, thanks for your answer but there is a problem, the "clearWindow" isn't transparent.
If I change the size or the position of this window (so that it doesn't overlap) I still see the environment in this "transparent" windows. Is this a bug or doesn't work the GL_STENCIL_BUFFER_BIT on my hardware?
Old 10-07-2010, 12:31 PM
The previous sample is incorrect. The following sample should do what you want:
#add a subwindow
#create info box in custom scene
import vizinfo
info_scene = viz.addScene()
info._group.parent(viz.SCREEN,info_scene)
#add a clearWindow that displays the custom scene
clearWindow = viz.addWindow(view=viz.addView(scene=info_scene))
clearWindow.setClearMask(0)
Old 04-11-2012, 05:09 AM
rlh001 rlh001 is offline
I have a similar problem. I want to run the main window on the 2nd screen of an extended desktop and keep the vizdlg.Panel() that I have already created on monitor 1. How can I place one item on each screen? thanks
Old 04-11-2012, 09:24 AM
You can change the position and size of each subwindow object so that it only appears on a specific monitor. Then you can add the panel to the desired subwindow.
Spatialized sound in Windows 7 GiudiceLab Vizard 3 01-27-2010 07:35 AM
rendering to displays that are not spanned by Windows desktop qwerty Vizard 3 12-11-2009 08:49 AM
addText problems with 3 windows Ravi Vizard 1 08-25-2008 05:51 PM
Best Way to set up wii cursors across 2 windows shivanangel Vizard 1 03-13-2008 11:24 AM
known windows firewall issue mspusch Vizard 0 06-01-2006 09:47 AM
