Old 01-30-2012, 11:55 AM
Enlil Enlil is offline
Using a texquad to cover a window
I was using texquads to blank out a window I made with viz.add(viz.Window) in Vizard 3, but it looks to me like the way texquads work with windows has changed in Vizard 4 (it appears the texquad is in effect behind instead of in front of the window).
So, is there a way to either attach a texquad to a window or is there a better way to fade to black?
Christian
Old 01-30-2012, 02:37 PM
Can you post some sample code? The following script shows one way to use a quad to fade the scene in/out:
viz.addChild('gallery.osgb')
fadeQuad = viz.addTexQuad(parent=viz.ORTHO)
fadeQuad.setScale([5000,5000,1])
fadeQuad.color(viz.BLACK)
fadeQuad.alpha(0)
fadeQuad.alignment(viz.ALIGN_LEFT_BOTTOM)
fadeQuad.visible(0)
fadeOut = vizact.sequence( vizact.method.visible(1), vizact.fadeTo(1.0,speed=1.0) )
fadeIn = vizact.sequence( vizact.fadeTo(0.0,speed=1.0), vizact.method.visible(0) )
vizact.onkeydown(' ', fadeQuad.runAction, vizact.choice([fadeOut,fadeIn]) )
Old 02-01-2012, 08:20 AM
Sure! I should have done that in the first place. My problem is not covering the whole screen - that still works. It is when I try to cover a sub-window I have a problem, as shown in the following code:
env = viz.add('tankmaze.wrl')
UpperRightWindow = viz.add(viz.WINDOW)
# NEED TO TEST REPLACING THESE COMMANDS FOR VIZARD 4
UpperRightWindow.setPosition(0.5, 1.0)
UpperRightWindow.setSize(0.5, 0.5)
UpperRightWindow.visible(0,viz.SCREEN)
quad = viz.addTexQuad(parent=viz.ORTHO, scale=[12.0, 10.0, 10.0],color=viz.BLACK)
quad.alpha(.5)
vq = ViewQuad()
#quad = viz.add(viz.TEXQUAD)
lake = viz.add('lake3.jpg')
#quad.billboard(viz.BILLBOARD_YAXIS)
#blackScreen = viz.addTexQuad(parent=viz.SCREEN,scale=[100.0]*3,color=viz.BLACK)
blackScreen = viz.addTexQuad(parent=viz.SCREEN,scale=[12.0, 10.0, 10.0],color=viz.BLACK)
blackScreen.setPosition([.5, .5, 0])
blackScreen.texture(lake)
blackScreen.alpha(0.0)
vizact.onkeydown(' ',blackScreen.runAction,vizact.fadeTo(1.0,time=2.0))
The quad covers the screen, but not the window. Normally I am only trying to cover the subwindow, but this shows the difference better.
Christian
Old 02-01-2012, 09:48 AM
When the parent of the quad is viz.ORTHO you can specify the subwindow to add the quad to with the scene argument:
subWindow = viz.addWindow()
blackScreen = viz.addTexQuad(parent=viz.ORTHO,scene=subWindow,scale=[500]*3,color=viz.BLACK)
Old 02-07-2012, 03:13 PM
Thanks, that was just what I needed.
Christian
Videos apearing in active movie window TarkaDahl Vizard 9 02-12-2016 02:43 PM
Limit vizinfo message to only one window? hotspur1 Vizard 1 05-07-2010 02:13 PM
tkinter window focus John P Vizard 4 08-31-2009 05:51 AM
texquad shai Vizard 1 02-23-2005 01:09 PM
The error window that couldn't FlyingWren Vizard 2 12-02-2003 08:23 AM
