Old 09-20-2011, 09:50 AM
new_horizon new_horizon is offline
viz.input
Hi All,
I am trying to enter some code that will allow the experimenter to enter a filename for the test subject - I would like this file name to be the participant number, however, when I input 01 or 02 etc, the program does not run.
Is there a specific command for allowing number entry? I assume the command below only takes care of string?
filename = viz.input('What filename for dataout?')
Old 09-21-2011, 10:48 AM
You can manually convert the string to an integer. Example:
strValue = viz.input('Enter a number:')
try:
	intValue = int(strValue)
	print intValue
except ValueError:
	print 'You did not enter a valid number'
Old 09-26-2011, 05:44 AM
Thanks for the reply.
Am I correct in saying however, that you cannot combine an integer and a string to make a file name?
For example if choiceM[selectM] is a string and filename is an integer?
filename = filename + choiceM[selectM]
Old 09-27-2011, 11:59 AM
Yes, just convert the integer to a string and then you can concatenate it with another string:
filename = str(filename) + choiceM[selectM]
character limit in viz.input message moooh Vizard 3 04-15-2009 06:27 PM
Mouse and Viz.Input bjgold Vizard 4 04-20-2007 02:21 PM
