Old 08-24-2011, 03:45 PM
Sakiot Sakiot is offline
A door question... left button mouse
Hello people, I am new in this program and the teacher gave us some homework... itīs kinda embarrasing because it may be something noob but I tried what my logic gave me in other programs... Here we go
The problem is that I have a door and I need to open it with the left button of the mouse; and then when the door is open use again the left button of the mouse to close it...
I already get how to open the door but I have problems with the closing...
This is my code for the action of opening and closing the door and also the code for the left button of the mouse (Sorry, its in spanish XD)
def clickIzquierdo(): #This def is to assign the action of the Left Button
objeto = viz.pick()
if objeto == puerta:
abrePuerta()
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,clickIzqui erdo)
def abrePuerta(): #This def is to open the door
puerta.runAction(vizact.spinTo(euler = [-90,0,0], speed = 10.0))
sonido_abre.play()
vizact.onkeydown("z",abrePuerta)
def cierraPuerta(): #This def is to close the door
puerta.runAction(vizact.spinTo(euler = [0,0,0], speed = 10.0))
sonido_cierra.play()
vizact.onkeydown("x",cierraPuerta)
By the words of my teacher is that I have to assign the def "cierraPuerta" in the def "clickIzquierdo"... but I dont know how to establish when the door is open and when is closed...The door always open but never closes it
Old 08-25-2011, 12:23 AM
sleiN13 sleiN13 is offline
you could use a global variable to save the status of the door. Or you could assign this variable directly to the door during construction.
puerta.abre = False (assuming abre is open )
then in the mouse even function check if the door is open or not and execute the appropriate function to open or close it.
Old 08-25-2011, 03:32 PM
Thank you very much, actually the use of a global variable cross my mind but... it didnīt work... this is my code with the global variable "estadoPuerta" (door status)
estadoPuerta = 0 #Global Variable
def clickIzquierdo(): #Left button action
objeto = viz.pick()
if estadoPuerta == 0:
abrePuerta()
if estadoPuerta == 1:
cierraPuerta()
def abrePuerta(): #Open door
puerta.runAction(vizact.spinTo(euler = [-90,0,0], speed = 10.0)) # Euler(Y,X,Z)
estadoPuerta = 1
sonido_abre.play() #Asignar sonido al picarle al boton de la puerta
vizact.onkeydown("x",abrePuerta)
def cierraPuerta(): #Close door
puerta.runAction(vizact.spinTo(euler = [0,0,0], speed = 10.0)) # Euler(Y,X,Z)
estadoPuerta = 0
vizact.onkeydown("z",cierraPuerta)
I am sure that my problem is the "clickIzquierdo" section and the use of IF and ELSE... Itīs my first time with the program and I still don't know so much (I have worked with C# and C++ and the logic is the same but... the way of writing it is different and thats my problem... I think).
Thank you for your attention =D
Old 08-26-2011, 12:45 AM
your code seems correct. language vizard uses is python you can work with that like c#
define classes will make things clearer most of the time.
class something(object):
also you could use if a == 'a' and b == 'b':
and elif instead of
if:
I replaced your door opening code with a print
print "print this string"
and I got the correct results so maybe check if your tabs are placed correctly for all the if statements.
Mouse bug in V3 and V4 Renato Lima Vizard 2 05-11-2011 06:38 PM
Mouse event: how to detect no mouse move event, how to set mouse position? Zhi Vizard 3 04-11-2011 06:25 PM
Warning mouse() -> Set mouse() of window johannes2 Vizard 1 08-19-2010 02:11 PM
