Old 03-14-2005, 08:45 AM
exhale exhale is offline
viewpoint roll / pitch
hello,
when i added these instructions to
my script, it looked as if the viewpoint
is always a bit pitched / rolled.
Is there a way to resolve this?
(i copied the values of the translate
from a viewpoint.get)
The problem arises @ translate()
removing lookat() does not seem to
affect the roll / pitch
view.translate(-6.2,1.8234411478,16.9)
view.lookat(17,0,20)
thanks in advance,
Kevin
Old 03-14-2005, 01:29 PM
The lookat command will orient the viewpoint so that it is looking at the given coordinate. The Y coordinate of the viewpoint is translated to 1.82 and you have it lookat a point with a Y coordinate of 0, so the viewpoint will have to be pitched down a little. If you don't want the viewpoint to be pitched then set the Y value of the lookat point to the same Y value of the translation (in your case, 1.8234411478)
Old 03-15-2005, 01:32 AM
hello,
allrighty i guess i didn't see that because i had been working on it for a bit too long hehe
thanks! greetz,
Kevin
