Old 07-01-2011, 11:40 AM
Karma Karma is offline
Failed to connect to intersense
I am trying to set up a 2 camera PPT-X system and for some reason the cameras are not picking up the calibration rig.
I tried running this code
PORT_INTERSENSE = 3
isense = viz.add('intersense.dls')
but I get this output
** Loading Test.py
intersense.dls           	Intersense Driver v4.0.4
** ERROR: Failed to connect to intersense on port 3.
** Load Time: 3.11 seconds
(the next part pops up when I close the test window)
InterSense Library ver. 4.04 32-bit
Copyright 1998-2007 InterSense Inc.
http://www.intersense.com
Tel: 781-541-6330
Looking for InterSense tracking device number 1.
Please wait ...
InterSense tracker not present
I saw a previous thread that said to check the port, but I think port 3 is the correct one to listen from.
At one point one of the camera was detecting the calibration rig but now it just looks like this.
Thanks for the help!
-Karma
Old 07-01-2011, 01:48 PM
Intersense
The following code should autodetect the intersense using the newer intersense.dle plug-in:
gallery = viz.addChild('gallery.ive')
isense = viz.add('intersense.dle')
tracker = isense.addTracker()
viz.link(tracker,isense)
You can also specify the port number in the addTracker command, it looks like it could be port 1:
tracker = isense.addTracker(port=1)
PPT Calibration
It appears there is no signal from the cameras, that's why they show red in PPT Studio. Verify everything is connected properly. If so and the cameras still appear red, contact support@worldviz.com for further assistance.
Intersense connection blessonisaac Vizard 2 12-06-2010 05:13 PM
world is tilting - intersense or code problem? billjarrold Vizard 2 11-06-2009 08:03 AM
intersense with 5DT glove sjp Vizard 2 04-06-2009 07:22 AM
intersense: Failed to set control word on \\.\COM1 OueOue Precision Position Tracker (PPT) 2 01-18-2007 12:51 PM
PPT talk button error: Failed to connect to COM4 jpq Precision Position Tracker (PPT) 3 12-08-2005 02:36 PM
