Old 02-16-2011, 07:02 PM
mizutani_jun mizutani_jun is offline
Error while running exe file
Hi.
I want to ask about exe file.
I create gui program and publish it as exe file.
It got no problem until i finish all the publish process.
But i got this error message when i want to run it as exe file.
See the attached files below.
It said that tcl wasnt installed properly.
I`m using Tkinter installer that i download from vizard official web page.
Any idea how to solve this?
Really need help.
Thanks.
Old 06-09-2011, 02:58 PM
kevin kevin is offline
I have run into the very same problem and was fortunate enough to stumble across the solution. I found that .tcl files are not picked up by Vizard when you run the program before you publish it. This results in the 'tcl not installed properly' error that you're getting.
In order to fix this, after you run the program and you're presented with a list of files to be included in the exe, open up a separate file browser and go the bin/lib folder in your Vizard directory. Then drag the folders tcl8.4 and tk8.4 into the exe publisher window in Vizard. Publish from there and it should work.
Good luck!
Closing of an imported .py file Uttama_vizard Vizard 2 05-04-2010 06:18 AM
IVEx file extenstion unrecognised. sindi Vizard 2 12-10-2009 01:20 AM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 02:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 09:44 AM
Problems loading dls file vnacooper Plug-in development 1 03-05-2007 09:26 AM
