Old 06-01-2009, 03:14 PM
Vic Vic is offline
Vizard not detecting PPT
I'm currently using Vizard 3.0 and executing some code following the format within the PPT documentation. However, whenever I run my code, I get an error message saying "Failed to connect to PPT on local machine". I've toggled the "Talk" button in PPT many times, but to no avail. I'm wondering what could have caused this error and how I can fix it. Thanks!
Vic
Old 06-02-2009, 11:45 PM
What version of PPT are you using and which output plugins do you have active?
Old 06-03-2009, 07:05 AM
Vic Vic is offline
I'm currently using PPT Studio 2008 and using VRPN 7 as the output.
Old 06-03-2009, 09:55 AM
Vic Vic is offline
I managed to get it working. Thanks a lot for the help!
Old 10-02-2009, 12:20 PM
funplorer funplorer is offline
Send a message via AIM to funplorer Send a message via Yahoo to funplorer
Vic,
I am having a similar problem.
How did you fix it?
Thanks in advance.
Old 06-07-2011, 09:38 PM
borryshasian borryshasian is offline
What if PPT and Vizard are on different PCs? Somehow the Vizard didn't get any data from PPT
Anyone can help?
Old 06-08-2011, 06:45 PM
Add the VRPN 7 output plug-in in PPT Studio.
Make sure all firewalls and virus scanners are disabled on both the PPT and rendering machines.
Place marker 1 in the tracking area and press Talk.
In Vizard run the following code, replace hostname with the name of your PPT machine:
vrpn = viz.add('vrpn7.dle')
tracker = vrpn.addTracker('PPT0@hostname',0)
gallery = viz.addChild('gallery.ive')
viz.link(tracker, viz.MainView)
Vizard and Augmented Reality realvision Vizard 4 04-04-2008 11:59 AM
Vizard won't run wouters Vizard 5 02-05-2008 12:12 PM
Fall 2007 release of Vizard R3 3 D Announcements 0 10-15-2007 05:50 PM
