Old 05-21-2011, 11:05 AM
FreakyT FreakyT is offline
Question Translating relative to orientation with matrices
I'm working a script that builds a world and outputs a new VRML file. I'm just doing it in Vizard so I can take advantage of the easy-to-use matrix calculation. Or so I thought...
Anyway, I need to build a road out of components that are rotated, and then translated relative to their orientation. My code looks like this:
current_transform.preTrans(0, 120, 0)
current_transform.preEuler(current_area_curvature, 0, 0)
The idea is that I first rotate the object, and then push it forward in the correct direction. However, when I call
current_transform.getPosition()
I just get [0, 240, 0], [0, 360, 0], etc. Is there any way to move the object relative to its current orientation?
Old 05-23-2011, 09:55 AM
Vizard uses the Z-axis for forward and Y-axis for up. Changing the code to the following should give you the behavior you are wanting:
current_transform.preTrans(0, 0, 120)
Old 05-23-2011, 08:16 PM
Ah, that did the trick. Thanks!
problem in setting the orientation of bones bharatbhushan Vizard 0 06-30-2009 05:30 AM
Loading OSG models and orientation Joran Vizard 4 06-18-2009 06:43 AM
orientation question whj Vizard 3 01-21-2009 12:22 PM
(beginner) calculating orientation change with eulers astull Vizard 16 02-22-2007 10:45 AM
translating viewpoint along body orientation cade_mccall Vizard 3 08-29-2006 10:35 AM
