Old 03-30-2011, 02:26 PM
Renato Lima Renato Lima is offline
Mouse bug in V3 and V4
So, if you are getting the mouse state it returns 1, 2, 5.. etc.. .. and it works well, but if you hold your mouse button down and move the mouse away from the window - or if another window gets in the way of the mouse - vizard won't detect that the mouse state has changed and will keep reporting 1, 2, 5, whatever.. until you click with the mouse again in the program.
1) create an event to report the mouse state every 2 seconds.
2) click on the screen and move the mouse away from vizard's windoe
3) release the mouse
--> vizard will still report the mouse as having buttons pressed.
Old 03-30-2011, 02:37 PM
This issue should be resolved in R4. I just tried the following script and the mouse state is properly updated when the button is released outside the window:
def PrintMouseState():
	print viz.mouse.getState()
vizact.ontimer(0.1,PrintMouseState)
Are you able to reproduce the issue with this script in R4?
Old 05-11-2011, 06:38 PM
Now the mouse state is being correctly updated, HOWEVER, if you do a viz.mouse(viz.OFF) hold down let and right mouse buttons and then viz.mouse(viz.ON), it will still think the mouse buttons are down.
Mouse pointer problem Albert Russel Vizard 2 02-21-2011 01:10 AM
Warning mouse() -> Set mouse() of window johannes2 Vizard 1 08-19-2010 02:11 PM
how to remove velocity when mouse is disabled? jvacare1 Vizard 2 02-18-2010 10:25 AM
Mouse problem steve Vizard 7 07-14-2005 03:01 PM
