Old 03-16-2011, 02:03 PM
xcuddlex xcuddlex is offline
Question artoolkit load 3d objects into application
greetings
i've found an example code on how to save a marker pattern on the resource directory. it works ! i love it. and i wonder is it possible to create a menu where user can load desired pattern and 3d objects into the application?
let say this is the initial code
#Create marker from pattern file
marker = camera.addMatrixMarker(0, width=1000)
#Add model
model = viz.add('ball.ive')
#Link model to marker sensor
viz.link(marker,model)
okay now how can i create a GUI menu where i can use to load the saved marker and 3d objects so that the updated code would be
marker = camera.addMarker('new.patt', width=1000)
#Add model
model2=viz.add('secondball.ive')
viz.link(marker2,model2)
is it possible to do so?
i've created the dropdown menu as below
#Create a menu subject
MainMenu = menu.add( 'Main Menu' )
#Main Menu
#Add dropdown list of theme options to Main menu
themeDropDown = MainMenu.add( viz.DROPLIST, 'Model')
themeDropDown.addItems( ['Import','Delete','Edit'] )
i'm a beginner. i never use python before. so i dont know how to put action handling into the menu.
if it can save a pattern. i think it is possible to load a pattern and 3d objects too. please help. i want to add and make the artoolkit more interactive. any suggestion on how to do it ? thanks
Old 03-17-2011, 05:33 PM
The vizmenu example script found in the example/graphicalUserInterface folder of the Vizard installation shows how to handle events for the different GUIs added to the menu. You can register a callback function for a GUI event where you can load the marker and model associated with the selection.
Old 03-29-2011, 05:59 AM
DamienH DamienH is offline
xcuddlex, is it possible to tell me where you did find the code on how to save a marker pattern ? Couldn't find any help on it and I'm interested in it for a project.
Old 03-29-2011, 03:54 PM
That script is called artoolkit_createPattern.py and it can be found in the examples -> artoolkit folder of the Vizard installation.
Old 03-30-2011, 07:36 AM
Thanks I have it (it was pretty obvious though ...).
But I have trouble when using a pattern I saved on the ressource directory in an other application. I have the message : " **ERROR: Failed to load AR pattern: 'C:\Prog[...]' "
Is it because of the name or the extension of my file (I tried many different names) ?
Thanks for your help
Old 03-30-2011, 07:48 AM
Problem solved, I was juste trying to load a MultiMarker instead of a Marker ...
Thanks anyway
Old 04-11-2011, 08:08 AM
jeff or anyone who are willing to help,
can you provide a sample code on how i can load a marker that i have saved ? i dont have any idea on how to do it. python is really hard.
Old 04-11-2011, 06:08 PM
You should be able to load a saved marker using the addMarker command with the name you gave it. Does that work for you?
#Create camera using first available webcam
camera = ar.addWebCamera()
marker = camera.addMarker('myPattern',width=1000)
Old 04-18-2011, 03:00 AM
hi jeff, yes it works
but i wanted to do a function where i can load it directly from my application
this is the code i found in the vizard resources
#Update raw pattern every frame
vizact.onupdate(viz.PRIORITY_INPUT-1,UpdateLargestMarker)
def SavePattern():
"""Displays save dialog for creating pattern from largest raw marker"""
if camera.largestMarker is not None:
parent = win32ui.CreateWindowFromHandle(viz.window.getHandl e())
dlg = win32ui.CreateFileDialog(0,None,None,0,None,parent )
if dlg.DoModal() == win32con.IDOK:
camera.savePattern(dlg.GetPathName(),camera.larges tMarker)
#Save current pattern when spacebar is pressed
vizact.onkeyup(' ',SavePattern)
i want to do the same thing for loading the saved pattern
for example, press ctrl+w to load pattern
but i dont have any idea how to do it because i never used python before
can you provide me any clue on how to do it jeff ? pseudocode is okay too.
i'll try to figure it out, thanks for the reply. really appreciate it
3d model, artoolkit, gui, load, pattern
Trouble picking text3d objects Salvar Vizard 4 12-01-2010 04:07 PM
Lightwave objects rotation problem hosier Vizard 6 02-13-2009 01:04 PM
Improve performance with large number of onthefly objects? Fox5 Vizard 7 04-28-2008 06:19 PM
