Old 01-04-2011, 10:49 PM
mizutani_jun mizutani_jun is offline
Vizard problem
Hi.
Please look at the attached files below.
I got this problem when i use vizard ( lite edition ) in my new computer.
I don`t think my lite edition caused the problem because i can use it without any problems in my old computer.
I can`t edit or save my vizard files in my new computer,so i need to use my old computer to change any command,save it and then overwrite it at this new computer before i can execute it.
It got no problem in execute the file but i can`t edit or save any command in this new computer.
So i assume there must be a problem within my new computer.
Really need help.
Thanks.
Old 01-04-2011, 11:29 PM
sleiN13 sleiN13 is offline
Do you run Vizard in administrator mode? I think you need administrator rights to be able to write files to de c:\Program Files\* folders.
You could simply test this by trying to save a .txt (notepad) file to the same directory.
Old 01-04-2011, 11:48 PM
I already did the test like you suggested.
And i think you`re right.
I can`t save my .txt (notepad) file to the same directory.
So how can i set my administrator rights to be able to write files to de c:\Program Files\* folders?
Thanks.
Old 01-05-2011, 03:58 AM
That's a windows thing don't know how to solve that. I always place my own vizard files in other locations because C:\program files\* is not really meant for it.
But you might be able to solve it by running Vizard with admin rights (right click vizard icon and select run as administrator)
Old 01-09-2011, 03:39 PM
Hi.
Thanks sleiN13.
Finally i solve this problem.
Just like you said,i tried run my vizard lite edition program as administrator and since then no problems occured.
My new computer currently using windows 7 and seems i still dont get used to it.
Thanks again.
Big problem with OpenSG exporter for max to Vizard omadawn Vizard 5 06-09-2009 11:51 AM
newbie problem getting vizard to work Colin Vizard 2 11-10-2006 10:54 AM
problem talking to usb device in Vizard Vbents Plug-in development 2 06-15-2006 03:08 PM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 10:52 AM
