Old 12-16-2010, 04:13 AM
psykoko psykoko is offline
data lose
I have an EEG system I'd like to use to send data to vizard over our network.
EEG System --> BCI Software ---> Network (UDP) ---> Vizard
so, when i send to data from BCI software to vizard, the data lose is induced. my BCI software data sampling rate is 256hz,
how can i get all data from BCI software to Vizard ?
Old 12-16-2010, 05:18 PM
You could try using the Python socket module to receive the data.
If you can send data via the parallel port you could try getting that in Vizard using the vizparallel.read command.
Old 12-16-2010, 07:21 PM
HI.
i don't know how can use vizparallel.read .
where can i search this example ??
if possible, i want to example code.
Old 12-16-2010, 08:08 PM
attach my code
import vizmat
import vizinfo
import socket
import struct
viz.mouse.setVisible(viz.OFF)
#The maximum amount of data to receive at a time
MAX_DATA_SIZE = 1024
#The port to send/receive data on
PORT = 8000
#Get the name of this computer
COMPUTER_NAME = socket.gethostname()
#Get the IP address of this computer
COMPUTER_IP_ADDRESS = socket.gethostbyname('localhost')
#Create a socket to send data over
OutSocket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
OutSocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
#Create a socket to receive data from
InSocket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
InSocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
InSocket.bind(('', PORT))
InSocket.setblocking(0)
viz.directormode(viz.DIRECTOR_FAST)
def SendData(data):
	OutSocket.sendto(data,(COMPUTER_IP_ADDRESS,PORT))
def ReceiveData():
	try:
		return InSocket.recvfrom(MAX_DATA_SIZE)
	except:
		pass
def onkeydown(key):
	if key == ' ':
		#Send data over the socket
		SendData('hello there')
def ontimer(num):
	#Try to receive data from socket
	data = ReceiveData()
	if data:
		udp = struct.unpack(">d", data[0][:8])[0]
		right = open('c:\\new\\new.txt', 'a+')
		right.write(str(udp)+'\n')
		print 'Received Message:',udp
viz.callback(viz.TIMER_EVENT,ontimer)
viz.starttimer(0,0,viz.FOREVER)
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 04:49 PM
Using 5DT plug-in with the data coming through network... mcicek Vizard 1 05-18-2009 05:17 PM
Flagging the Data Elittdogg Vizard 5 04-11-2008 11:40 AM
Data Files betancourtb82 Vizard 6 05-04-2006 02:43 PM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 08:48 AM
